Opinion on motor status 292
Posted By capelo 7 Years Ago
capelo
Posted 6 Years Ago
Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)
Posts: 279, Visits: 4.5K
after a good fight got 👍
Posted 6 Years Ago
Good to see you got that threaded plug out.  They can be problematic at times.
While heating the plug and dripping beeswax on the threads seems to be the accepted way to remove those, I just haven’t had much luck doing it that way.  I end up having to drill a hole in the plug and use a square style broken screw extractor to remove those plugs.  I like to run taps in all the threaded holes before vatting to insure that the threads are clean and undamaged.
Posted 6 Years Ago
Posts: 3.7K, Visits: 498.2K
Another way of moving stubborn plugs or broken bolts is to weld a nut on it.
capelo
Posted 6 Years Ago
Ted (1/6/2020)
I have already checked all the threads and everything is ok
capelo
Posted 6 Years Ago
paul2748 (1/7/2020)
that is a good solution already used on occasion 👍
capelo
Posted 6 Years Ago
I feel very upset with this, I bought a new oil pump thinking it would be gerotor, a failure
capelo
Posted 6 Years Ago
a necessary change
capelo
Posted 6 Years Ago
Any suggestions for installation?
Posted 6 Years Ago
Gerotor pumps aren't available new.  Rebuild kits are available, Melling K-56, if you can find a good used one to rebuild.
Posted 6 Years Ago
Heat the ring gear in the oven, the other part in the freezer
capelo (1/9/2020)
