Opinion on motor status 292
Posted By capelo 7 Years Ago
Posted 6 Years Ago
Posts: 3.7K, Visits: 498.2K
Heat the ring gear in the oven, the flywheel in the freezer
capelo (1/9/2020)
Any suggestions for installation?
capelo
Posted 6 Years Ago
Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)
Posts: 279, Visits: 4.5K
charliemccraney (1/9/2020)
Gerotor pumps aren't available new.  Rebuild kits are available, Melling K-56, if you can find a good used one to rebuild.
Ok thanks 👍
capelo
Posted 6 Years Ago
this serves for me 292…?
capelo
Posted 6 Years Ago
So were my valves, any opinions? How can I proceed for cleaning?
Joe-JDC
Posted 6 Years Ago
Last Active: 1 hour ago
Posts: 796, Visits: 23.2K
If you have access to a soda blaster, it will clean those valves quickly.  If not, what you can do is spin them in a drill press and use a wire brush in an electric hand drill to clean the carbon.  Others have soaked them in carburetor cleaner and used scotch brite pads, or you can carefully spin them with a drill and use a 100 grit crocus cloth to remove the carbon.  I have seen some folks use a bench grinder with a wire wheel and wear leather gloves to hold the valves and rotate them to remove the carbon.   Many options, if you have any of these things available there.  Joe-JDC
carl
Posted 6 Years Ago
Last Active: 7 days ago
Posts: 1.2K, Visits: 20.7K
Oven cleaner will clean the carbon off of the valves     Carl
capelo
Posted 6 Years Ago
Joe-JDC (1/11/2020)
thank you note I will try to acquire a blaster soda
capelo
Posted 6 Years Ago
carl (1/12/2020)
I have tried it on the cameras they take a lot, but on the resistor valves, thanks
capelo
Posted 6 Years Ago
capelo (1/11/2020)
anyone about this?
Posted 6 Years Ago
Not sure, but that clutch assembly is not listed for a Y-Block.. so ?
