Opinion on motor status 292
Posted By capelo 7 Years Ago
capelo
Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)
Posts: 279, Visits: 4.5K
the old one seems somewhat deformed, the one at the top can be the spare part ..
capelo
different but the same?
capelo
capelo (12/9/2019)
The old one seems somewhat deformed,  The one at the top can be the spare part .
http://forums.y-blocksforever.com/uploads/images/a9582869-88d9-4461-9cde-7c70.jpg
There’s no 'top' rear seal retainer on my screen but the one on the right (has only one oil pan stud) would appear to have been damaged by a flywheel bolt that was too long.  Be sure the flywheel bolts do not protrude beyond the thickness of the crankshaft flywheel flange when bolting up the flywheel.
capelo (12/9/2019)
Different but the same?
http://forums.y-blocksforever.com/uploads/images/a8e72b03-0b93-4791-810e-db5e.jpg
Look for ‘EBU’ on the opposite sides of the rods.  If ‘EBU’ is present, they are the same.  Beyond that, as long as the rods are the same length and the small/big end weights are reasonably close as a set, they can be used as a set after rebuilding and balancing.
capelo
capelo
Can this be a problem?
capelo
there is a small difference ...
capelo
capelo
how do they look?
