Visits: 4.5K
Visits: 4.5K
Visits: 4.5K
only two head bolt sizes
Visits: 4.5K
Visits: 22.3K
the block would have came with the holes.i had the same setup years ago and drilled the holes in a set of g heads.i never bothered after that.ive noticed over the years that a lot of new ideas for y blocks were dropped later.
Visits: 4.5K
Visits: 4.5K
If the paint is not designed for continuous contact / submersion in oil, then every bit of it needs to be stripped from the inside of the oil pan.
Visits: 4.5K
[cita] [b] charliemccraney (12/08/2019) [/ b]
Si la pintura no está diseñada para un contacto continuo / inmersión en aceite, entonces cada parte debe ser eliminada del interior del cárter de aceite. [/ citar]la bandeja de aceite parece estar recubierta de polvo
Just the same. You do not want it to deteriorate and flake of and clog the oil pickup or get into the oiling system.
