Visits: 285.6K
I have located an Edelbrock 257 Manifold in NOS condition. The price seems reasonable, so I am going to pull the trigger. I am now contemplating the carbs. I can buy some old carbs and deal with those issues, or find some new carbs that will work on my Y Block. Edelbrock 500 cfm Thunder Series AVS carburetors are one option. I already have a new Holley 0-1846-1 465 cfm carb on my motor now. If I buy another just like it, I can run dual Holleys. Both options require adapter plates. I believe both options will fit under my 55 TBird hood with small air cleaners. Will I have to mount the Holley carbs sideways? I have seen some mounted straight like an FE motor. Where do I buy linkage? Do I connect both primary shafts together?
I don't think modern Holleys will fit without either custom adapters or mounting them sideways, which complicates linkage.
Last Active: 5 hours ago
Visits: 23.1K
Y Block intakes are dual plane, and need the carbs mounted front to back, not sideways. Your primaries would both be on one side. Edelbrocks, teapots, will work and look great. I have Edelbrocks on my 257, and if I remember correctly Vic C races Edelbrocks on a 257. Joe-JDC
At least some of the 2x4 intakes can have the carbs mounted sideways and still function as dual plane because the planes criss cross each other, rather than parallel like a single carb intake. Is the Edelbrock not one of them?
Visits: 285.6K
Here are two photos of a Y Block with Holley carbs mounted in line. How is this done?
Visits: 285.6K
Last Active: 11 hours ago
Visits: 285.6K
Thanks Ted. Those are great photos. Where can I buy linkage like that? Can you please comment on the drive ability of this setup? I realize that is a lot of CFM for a 292. I doubt my secondaries will ever open.
Last Active: 12 hours ago
Posts: 2.0K,
Visits: 306.5K
Many of the dual quad manifolds for the Y can facilitate mounting the carburetors sideways and not inhibit air flow to the banks due to the staggered inlet pattern within the plenums.
-TED
