TBird Multiple Carb Options
Vic Correnti
Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)
Last Active: Today @ 12:20:18 AM
Posts: 350, Visits: 12.3K
Here is a picture of my eye candy, 2 600 CFM Edelbrocks on a 257 Edelbrock manifold with adapters from Speedway and fit in my 55 Bird. This combo was dyno'd at 15 HP less then a Holley 750 and Mummert intake. I have had the carbs on a 255 intake and that was an easier filter fit then the 257. I have had 2x4's on this car since the 60's and wouldn't have it any other way. Once the Edelbrocks have been tuned I have never touched them. I have had the front carb and the rear carb as the primary and it doesn't matter, right now they are both linked together.
http://forums.y-blocksforever.com/uploads/images/25b12b33-1840-404a-b09f-4648.jpg
Last Active: 5 days ago
The AFB's will need the 1/2" spacers but I still think they will fit under the hood. I see the one carb with the choke removed has a set of those booster "collars" that lower the CFM. Anyone else ever try them? I would think for the use of AFB's it would be a good thing since finding the 400's is getting difficult.
That is a consideration.  Easy fix, though.  You could send a message and make an offer.  If nothing else is wrong besides some stripped carb flange threads, I'd jump on it.  Things like that need to be had when they become available.  Could be waiting around a while for another to show up.
If you get Y Block Magazine, check those classifieds, too.  I think there has been a 2x4 of some kind listed there recently.
Posts: 1.2K, Visits: 285.6K
The EBay asking price for the 257 is $600 and the manifold has some stripped threads.  Seems high to me. It would be worth the money if it didn't have issues.
There is a 257 on ebay right now, https://www.ebay.com/itm/FM257-Vintage-edelbrock-intake-manifold-Y-block-Ford/183524392684 . When Ted tested 2x4  intakes, the 255 actually did a little better.  Could be a fluke with the particular intakes used but 2 sets were used with the same result, 1 set stock and 1 set ported.  http://www.eatonbalancing.com/2014/01/17/y-block-ford-dual-quad-testing-on-aluminum-heads-part-ii/
The same trend existed with the '56 and '57 Ford manifolds.
Measurements would be helpful. I am leaning toward dual AFBs.  The best carbs for me won't be polished.  There is a rebuilt set on EBay right now.   I can't imagine two of these would have hood clearance issues.  These would look great on my TBird with a couple of small Cobra style air cleaners. If I can find a decent manifold, I would be good to go.  I've had some issues with old aluminum manifolds before. It can cost more to fix one than their worth.
http://forums.y-blocksforever.com/uploads/images/bf7b763c-373b-4348-89da-75b6.jpg
Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)
Last Active: 12 hours ago
Posts: 2.0K, Visits: 306.5K
It would be nice if all of the differing intake types, both 6V (EDEL 553 and 573) and 8V (56 and 57) intakes were measured and the results listed here for future reference(s), in this instance from valley pan to intake plenum heightshttp://forums.y-blocksforever.com/uploads/images/6f5dbf95-05a4-4382-a680-c4dc.jpg.
Also, carb heights (2V and 4V) base to throttle body ACL MTG boss) in the same fashion as the 8V setups CTR to CTR measurements
Florida... If you want I'll measure from the valley cover pan to the top of the carb air horn. Front of the front and rear of the rear of my dual quads. The manifold is an Edelbrock and carbs are Carter WCFB's there are 3/8" phenolic spacers under each one. The stock Ford manifold is probably lower.. I don't know anyone with 3-2's I can measure.
Posts: 3.7K, Visits: 498.2K
I think it is the back carb that is a problem with a TBird hood.  I understand some owners shaved down the mounting flange to get the needed clearance.  One person that I talked about clearance said that he did machine down the flange (or flanges)
Florida_Phil (11/28/2018)
Thanks.  I asked for pics.   Do you think these can be made to clear a 55 Thunderbird hood?
Can't comment on hood clearance  issues, but if going with Tri- Power & wanting any sort of performance improvement, "pass" on the Offenhauser intake. Ted's testing of 7 Tri Power setups rated that intake dead last!.. They sold well in their day, based on the storied reputation of Fred Offenhauser (Sr.) but the Y-block intakes were not built by his company, but by a relative's company with the same name..
