Finnish Drag Race Championships
Posted By Hollow Head 13 Years Ago
yfreak57
Posted 13 Years Ago
Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)
Last Active: 9 Months Ago
Posts: 100, Visits: 1.0K
...meanwhile something different!!!
-jyrki from Finland-
www.hollowheads.net
Hollow Head
Posted 13 Years Ago
Posts: 1.0K, Visits: 3.8K
Two new motorsport videos. This is our 8.885 run from June...
http://www.youtube.com/watch?v=8_jATbrygbU&feature=c4-overview&list=UUxZ94DRcBfpz0DstGIV1_QA
And this is how the engine broke last Thursday...
http://www.youtube.com/watch?v=_4tpqEX8DyI&feature=c4-overview&list=UUxZ94DRcBfpz0DstGIV1_QA
Hollow Head
Posted 13 Years Ago
Looks like camshaft and lifters are ok and pushrods and roller rockers too. Crankshaft has to be measured and possibly #1 and #5 rod journal have to be grind to undersize 2.100. Other journals might be ok with only polishing. So, we only need one block machined, heads fitted with larger valves, one new piston and two connecting rods to build a new engine. And oil pump and shaft Angry...
http://forums.y-blocksforever.com/Uploads/Images/0c34c830-f7a3-4bf9-9b5f-0d13.JPG
Hollow Head
Posted 13 Years Ago
We were preparing our dragster today for the next event on coming saturday and with Jyrki's old normally aspirated engine. Some problems occurred during the cam break in as the distributor gear pin was broken and we didn't realize that before the engine warmed up and started running badly. The gear spinned over the axle and ignition advance got screwed! That breakage happened at the last race where our turbo engine destroyed.
http://www.youtube.com/watch?v=WvGmUd4mQns&feature=c4-overview&list=UUxZ94DRcBfpz0DstGIV1_QA
So, tomorrow we will install a new pin and do some more tuning and then go for the hunt of high 10's or low 11's BigGrin.
Hollow Head
Posted 13 Years Ago
16 ladder elimination today and Jyrki took a red light at semi final and we lost to Janne Noren's Chevy powered '34 Ford! 11.859 / 175,69 was best the normally aspirated Y could do with non ported heads and about 10.4 to 1 compression. Seven runs this weekend and three 0.001 sec reactions. All runs in 11.859 to 12.004 range and all top speeds within 173 to 176 km/h! One race weekend to go this year...
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Sunday/MOP_2559.jpg
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Saturday/MOP_1756.jpg
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Saturday/MOP_1755.jpg
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Saturday/mop1+(177).jpg
Hollow Head
Posted 13 Years Ago
And a short video about one 11.9 second run. Doesn't even lift the wheel without turbos Angry. And that steering does some strange moves when turning... Whoops! 60 ft times were around 1.6 seconds.
http://www.youtube.com/watch?v=zZppujef1O0&feature=youtu.be
glrbird
Posted 13 Years Ago
Posts: 616, Visits: 7.1K
Seppo
That is a huge turbo sticking out of the orange chevyII, and does the blue mopar run 8.0's, Nice looking top quality cars. Looks like it was quite a show. Hope you get your turbo engine back together soon. Any plans to get the kids a JR dragster?
Gary Ryan San Antonio.TX.
Posted 13 Years Ago
Sorry to hear that Hollow heads lost their engine block.. However, have followed their exploits here & in Y-Block magazine for some time. Sorry, but I'm not surprised, as I think they have been expecting to much. This is a case of to much Turbo charging & not enough time & money spent on the engine under the turbos...
Posted 13 Years Ago
Posts: 4.6K, Visits: 39.4K
I'm not sure what they did to the bottom end but it was pretty stout. If it didn't have a girdle and reworked caps/bolts it probably will soon. They are far below their fastest, more is yet to come.
Are you following the super horsepower twin turbo pickup on the forum? I'm still waiting for it to over test its bottom end. w00t Chuck
Hollow Head
Posted 13 Years Ago
Paul, you are right about money spent. With more money and time we could have gone to dyno more often, but it takes 500 euros each time.
Chuck, you are right about that bottom end. It really is stout and can handle a lot torque and horsepower if balanced right. Even with stock bolts. Don't remember if Hutz is using ARP stud in his engine, but we had stocks. And that our mishap did'n come from bottom end...
And, about our expectations... Sure, we expect a lot but we still are sure we will do it. It's just to get all things together and working right. Going fast isn't easy or cheap, but it's fun! Is there really any point to stick with carbs and without boost BigGrin.
