Finnish Drag Race Championships
http://forums.y-blocksforever.com/Topic82866.aspx
By Hollow Head - 13 Years Ago
Jyrki drove to runner up position at Motopark Spring Nationals yesterday. We lost both turbos after three qualification rounds on saturday and had to take them off and continued. Jyrkis 0.01 reaction time put us to number two position after qualification and then we set our index to 11.99 and that caused focusing problems to our competitors BigGrin. So, good weekend, but expensive... Pics and vids will come later.
Way to go guys!!!
Here is some pics.
http://forums.y-blocksforever.com/Uploads/Images/0f364464-d67c-4154-960b-1573.JPG
Team with new shirts.
http://forums.y-blocksforever.com/Uploads/Images/088ffb42-49a4-4398-88e8-e454.JPG
Lunch break. From left Markku, Jyrki and Simo.
http://forums.y-blocksforever.com/Uploads/Images/0889dbf3-d6a8-4d25-b22a-d69f.JPG
Power adders removed...
http://forums.y-blocksforever.com/Uploads/Images/d4401fbc-a7ab-4a31-bf7a-bc03.JPG
Runner Up Jyrki with winner Hannu Tekoniemi who raced with 512 cid AMC Javelin SST.
http://forums.y-blocksforever.com/Uploads/Images/e304e103-e74c-4fd3-b8ba-c8aa.JPG
Simo and Jyrki posing with Dragster without Turbos.
And the video about that final run...
http://www.youtube.com/watch?v=ni-r-rBBtck&feature=youtu.be
By glrbird - 13 Years Ago
What happened to the turbos that you lost both at the same time? Great job changing back to natural asperation and driving to runner-up.
By Talkwrench - 13 Years Ago
Anybody want two used hair driers ...??!!! Laugh
It seems to be that turbos did not get enough or at all oiling. When we put the engine together, we tested oil feed by cranking the engine with hose end of the turbos in canisters and oil feed was good. But after the failure turbos seem to be dry. Turbos are now sent to service and we sure hope they can fix them. Bearings to both, axle and wheels to right one and possibly axle to the left one. Six weeks to next race and we really want to go faster than 11.95 then... We are thinking about external oil pump to feed the turbos.
By LordMrFord - 13 Years Ago
11,95 is quite good with 292 cid, ~8.5 cr and small exhaust outlets, I think.
By pegleg - 13 Years Ago
LordMrFord (5/21/2013)
THAT would be an understatement! That's real good.w00t
More video material from our last race... Enjoy!
http://www.youtube.com/watch?v=8viwnpRnDjg&list=UUxZ94DRcBfpz0DstGIV1_QA&index=1
Engine is now back together again and today was the time to do some fine tuning. And we did it for the fun of our neighbours again BigGrinBigGrin! Here is the proof...
http://www.youtube.com/watch?v=i8pisGKR6Fc&feature=youtu.be
sweet.
By bird55 - 13 Years Ago
Cool!, not too much fun for that flame suit though! BigGrin
By Rono - 13 Years Ago
GREAT photos and video guys! Congratulations on your win!
Rono
Alan, that garage wear was there for a purpose BigGrin. Last time we did the same, exhaust pulses made a huge dust cloud out of a dry sand and that was a no no with open turbos w00t.
So the idle advance is about 10 degree, max at 3000 rpm is 40 if running without boost. When hitting that 1.5 bar/22 psi, advance is 20 at 3000 rpm. Those numbers are not a dyno proven, so those are results of hunch of team's brainstorm aided by more badass turboracers.Doze So if anybody got more ideas to this soup of speculations, feel free to leave a comment.
By wlj1943 - 13 Years Ago
Great job guys. Congratulations!!One possible issue?
Many years ago I worked at Garrett AiResearch. I assume you have check valves in the turbo oil feed lines at the lowest point to avoid oil drain back? This was an issue on the first Offy turbo engines built for Indy in the 1960's; we had bearing failures that occurred on restarts with hot oil. This engine too had turbos mounted high up. Some engine builders also use an accumulator or auxiliary electric oil pump as well.
WLJ
Good info WLJ. Thanks. In fact we have no check valves and that have not even came to my mind w00t. But, this is learning all the time...
Thumbs up for the weekend. Tomorrow is first qualification day, saturday is another qualification day and then hopefully we will be in sundays eliminations too. I'm quite positive that we will go faster than 8.723 this weekend Whistling. But, there is always a chance for rain to ruin our weekend...
We lost today on the second elimination round as Jyrki broke his 9.01 dial in by 8.885 / 226 km/h run with 1.217 60 ft time. We struggeled all weekend with fuel and ignition maps and last run on saturday and first run on sunday went badly due poor and slippery track conditions after someone oiled the track. Here is the list of runs:
R/T -.003 60 ft 1.487 ET 9.467 speed 227.62 km/h
-.018 1.245 9.126 224.94
.039 1.337 9.616 216.43
.046 1.258 9.226 224.03
-.024 1.309 9.037 232.15
.039 1.353 9.281 223.65
.090 1.350 9.832 213.25 one boost pressure hose got loose and sliding on slippery track. Won this as other guy red lighted.
.406 1.217 8.885 226.17 lost due break out
So, not the weekend we wanted, but the car is still in one piece and it's good to go to next race on next thursday to sunday Smile. We just have to get more ignition advance with 1.5 bar of boost to gain some more trap speed...
One nice picture about our dragster... http://www.zegetion.com/Racing/DragRacing/FHRA-DRW-2013/30241113_h3TNtC#!i=2606646044&k=k7SnfGB&lb=1&s=A
Seppo, That's a very nice picture, one of the best I've seen of your car. The look on the starters face... What the ???? (WTF) is that? Awesomew00tw00t
http://forums.y-blocksforever.com/Uploads/Images/c5f2d30c-99d6-47b5-b409-2591.png
A few seconds before a total destruction.
http://forums.y-blocksforever.com/Uploads/Images/a675075a-ccc2-4c7d-b9b9-da25.jpg
By MoonShadow - 13 Years Ago
Please tell us more? Total destruction sounds terrible. What happened and is everyone ok? Chuck
No casualties but Seppo and Jykä might have a mighty headache in tomorrow morning.I dont wanna spoil the official catastrophe report but there might be a couple of big holes in side of the block.
Jeah... One exhaust valve broke and then the piston and rod came through the wall... So, we lost a cylinder! Totally w00t. That was in qualification run number three on Thursday and in about 1000ft. 6400 rpm and 1.55 bar of boost. Main reason is suspected to be too soft valve springs with boost. So, Jyrki and I have been trying to be just a little drunk ever since that happened... Two more days to go and then back home collecting money to build a new bottom end.http://forums.y-blocksforever.com/Uploads/Images/921b2338-be51-4d92-9c1d-ff08.JPGhttp://forums.y-blocksforever.com/Uploads/Images/b8381424-a6e0-4d6a-a061-1bf1.JPGhttp://forums.y-blocksforever.com/Uploads/Images/c4d05168-996f-4ce3-8f82-9fd1.JPGhttp://forums.y-blocksforever.com/Uploads/Images/bb09cfac-e931-488b-9530-db36.JPG
Man, when you guy's break stuff, You really BREAK STUFF!!!!!!!!!! Sorry for your loss.
Wow.
Ditto on Charlies WOW! If you keep breaking them like that we'll have to put you in touch with Pat in Texas. He splits the blocks completley. Somehow I don't expect you to find much useable out of that one. Good luck though. I hope this dosen't put you off racing. It is an expensive hobby though. Chuck
By Carson - 13 Years Ago
There is an ol Finnish saying that translates something like " a few eggs will break when one makes an omelet "
question Seppo... were does the coil wire go w/ dist on top of your head ??
giggy up, Carson
Yep, it's broke!Crying
By yfreak57 - 13 Years Ago
...meanwhile something different!!!
Two new motorsport videos. This is our 8.885 run from June...
http://www.youtube.com/watch?v=8_jATbrygbU&feature=c4-overview&list=UUxZ94DRcBfpz0DstGIV1_QA
And this is how the engine broke last Thursday...
http://www.youtube.com/watch?v=_4tpqEX8DyI&feature=c4-overview&list=UUxZ94DRcBfpz0DstGIV1_QA
Looks like camshaft and lifters are ok and pushrods and roller rockers too. Crankshaft has to be measured and possibly #1 and #5 rod journal have to be grind to undersize 2.100. Other journals might be ok with only polishing. So, we only need one block machined, heads fitted with larger valves, one new piston and two connecting rods to build a new engine. And oil pump and shaft Angry...
http://forums.y-blocksforever.com/Uploads/Images/0c34c830-f7a3-4bf9-9b5f-0d13.JPG
We were preparing our dragster today for the next event on coming saturday and with Jyrki's old normally aspirated engine. Some problems occurred during the cam break in as the distributor gear pin was broken and we didn't realize that before the engine warmed up and started running badly. The gear spinned over the axle and ignition advance got screwed! That breakage happened at the last race where our turbo engine destroyed.
http://www.youtube.com/watch?v=WvGmUd4mQns&feature=c4-overview&list=UUxZ94DRcBfpz0DstGIV1_QA
So, tomorrow we will install a new pin and do some more tuning and then go for the hunt of high 10's or low 11's BigGrin.
16 ladder elimination today and Jyrki took a red light at semi final and we lost to Janne Noren's Chevy powered '34 Ford! 11.859 / 175,69 was best the normally aspirated Y could do with non ported heads and about 10.4 to 1 compression. Seven runs this weekend and three 0.001 sec reactions. All runs in 11.859 to 12.004 range and all top speeds within 173 to 176 km/h! One race weekend to go this year...
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Sunday/MOP_2559.jpg
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Saturday/MOP_1756.jpg
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Saturday/MOP_1755.jpg
http://kuvia.1g.fi/#/kuvat/Tapahtumat+2013/FHRA/Blåkläder+August+Nats/Saturday/mop1+(177).jpg
And a short video about one 11.9 second run. Doesn't even lift the wheel without turbos Angry. And that steering does some strange moves when turning... Whoops! 60 ft times were around 1.6 seconds.
http://www.youtube.com/watch?v=zZppujef1O0&feature=youtu.be
Seppo
That is a huge turbo sticking out of the orange chevyII, and does the blue mopar run 8.0's, Nice looking top quality cars. Looks like it was quite a show. Hope you get your turbo engine back together soon. Any plans to get the kids a JR dragster?
By PF Arcand - 13 Years Ago
Sorry to hear that Hollow heads lost their engine block.. However, have followed their exploits here & in Y-Block magazine for some time. Sorry, but I'm not surprised, as I think they have been expecting to much. This is a case of to much Turbo charging & not enough time & money spent on the engine under the turbos...
I'm not sure what they did to the bottom end but it was pretty stout. If it didn't have a girdle and reworked caps/bolts it probably will soon. They are far below their fastest, more is yet to come.
Are you following the super horsepower twin turbo pickup on the forum? I'm still waiting for it to over test its bottom end. w00t Chuck
Paul, you are right about money spent. With more money and time we could have gone to dyno more often, but it takes 500 euros each time.
Chuck, you are right about that bottom end. It really is stout and can handle a lot torque and horsepower if balanced right. Even with stock bolts. Don't remember if Hutz is using ARP stud in his engine, but we had stocks. And that our mishap did'n come from bottom end...
And, about our expectations... Sure, we expect a lot but we still are sure we will do it. It's just to get all things together and working right. Going fast isn't easy or cheap, but it's fun! Is there really any point to stick with carbs and without boost BigGrin.
Hollow Head (8/13/2013)
Paul, you are right about money spent. With more money and time we could have gone to dyno more often.
...or buy the aluminum heads and stroke the crank.
Since the failure was caused by a broken valve..the question is, was it a used stock valve? And, what kind of valve springs were used? Are the valve keepers original factory etc? Ford only recommended a max of 5400 rpm for the standard stock component valve train. On the Dyno tests, was there indication of valve float ? All questions that need to be answered to avoid a nasty repeat episode..
Ferrea stainless steel 1.84 intakes and 1.70 exhausts. Comp Cams 942-16 springs without damper coils as they did't fit with non massaged guide bosses Angry. Comp Cams retainers and locks. So, that exhaust valve broke simply because of too soft spring set up and valve beeing too large diameter for our stock bore size and hitting the corner of the cylinder wall. Nothing secret here, just old stupidity. Also, Harland Sharp 1.6 roller rockers helped lifting the valve too far... And causing several bend push rods. Push rod cup end breakings were caused by too wide ball ends as discussed in different topic earlier. So, we are learning the hard way and piece by piece, but be sure our next engine will be even more aggressive and records will be broken. If not the WR, atleast our own. We will double our injector size as now used duty cycles show that we don't have enough fuel flow with E85 and 1.5 bar of boost. And something else too BigGrin. Visiting the dyno with time and money collected during the winter time...
Seppo
One thing about learning the hard way, you will not make those mistakes again. Not only is it expensive, but you don't get to race when your car is broke. I think your group has come a long ways from the hot rod. Keep the Faith, baby!
By Jim - 13 Years Ago
Way to go guys, and to think that I was a witness to the original "Hollow Heads" engine firing up for the first time. Everyone keeps coaxing more horsepower and lower ETs out of our old powerplants. Would love to see you guys at Columbus! I just bet that someone would stick you in a car!
Jim, funny that you mentioned our Hollow Machine engine. We just sold that one to our friend in Tampere and it will power one customized '53 Ford that was originally four door sedan and it is now two door chopped custom. Time flies, but I doubt that we come to Columbus this year. We are afraid to be put to stick cars with carbs BigGrin. Would be funny though, to see all you there...
I am retiring on Friday, and will be heading to Columbus with Ted Eaton next Wednesday morning. See if you guys can put a trip together for next year. I'd enjoy seeing whoever would come but especially you and Jyrki!
Please Jim, take a lot of pics and do a full coverage to our Ford-Freak Magazine about Y-block Shootout. Are you going to drive with your car this year? You should...
Jim,
Be careful, we haven't seen you since the last time you "retired". Are you sure you can add another workload like the last one? I never worked so hard in my life until I retired! But I am catching up on the Honey do's. Chuck
Some little progress when preparing ourselves to next season...
http://www.youtube.com/watch?v=hUjHQJI-lK0&feature=youtu.be
New block is coming as other little updates also, so we really hope we can do better and go faster than this year.
So what I want to know is how does it handle with snow tires? Chuck
I guess it turns around lot better than with slicks... Hmmm, maybe we have to try that too. Looks cool...
http://www.youtube.com/watch?v=6lJaDC5U45Q
Considering your short summer you should get something like that going over there. I'm sure you already have ice races. Just have to get them to straighten the track a bit. Does look like winter fun. Chuck
Chuck, indeed we have ice races but on past five to ten years all races here in southern Finland have been cancelled due too thin or at all ice on the lakes. Even the motorcycle races have been cancelled as tractors would have gone through ice when clearing the track. And also the "green" peoples have caused problems and most of the southern lakes are not allowed even for boats with motors and so cars over the ice are also a no no! Soon they propably will cancel all skiing on ice and snow as the ski waxes dirt the earth...
But, we still have some nice things going on... LSR racing on ice!
http://www.youtube.com/watch?v=TS3zx8NMlr8
http://www.youtube.com/watch?v=wHZ0RdYz0g0
By Hollow Head - 12 Years Ago
New engine for season 2014 is on it's way.
By slick56 - 12 Years Ago
Nice job!!!
How many hours went into that timing cover?
