Initial timing
Posted By B-rad 7 Months Ago
B-rad
Posted 7 Months Ago
Posts: 348, Visits: 1.5K
I finally was able to get my 317 primed with oil up to the rockers. I had to turn the crank to line up something, I guess.
I'm trying to get the engine set up to drop the dizzy in. I know the #1 piston is at the top and the timing mark is lined up. Does that mean it's ready for the dizzy to go in? Don't want to have to redo once the engine is in. I attempted to put the dizzy in but it didn't want to go down the last 1/4". Maybe it's not lining up with the intermediate shaft? I am using the hex dizzy and oil pump.
Any help timing and installing dizzy is appreciated, along with any engine installation issue remedies. I took the engine and tranny out about 3 years ago and my memory is slowly fading.
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Joe-JDC
Posted 7 Months Ago
Posts: 772, Visits: 22.6K
If you had compression in the #1 cylinder as it came up on TDC, then you are at the correct position.  You can have #1 up but not on the compression stroke.  Pull #1 plug and rotate the engine over and hold your finger in the sparkplug hole as you rotate the engine over.  It will spit your finger out as it comes up on compression.  Set the timing mark at ~25*btdc and install the distributor.  Check that the rotor is pointing to #1 plug terminal and not #6 or what number is in the firing order.  Installing the distributor at ~25* will allow it to start and run fast while you are closing things up, checking water level, and then you can concentrate on setting initial timing.  I would set it at 12-14* and try it there.  Joe-JDC
B-rad
Posted 7 Months Ago
Thx Joe. So the timing mark will be on the pointer both times the piston is at the top? Trying to do this alone, so it's difficult to turn the crank and check for compression at the same time by myself. Does it matter if I turn motor cw or ccw to move the piston?
Brad
1954 Lincoln Capri
Joe-JDC
Posted 7 Months Ago
Always try to move the engine in clockwise direction so that the bearings will be properly oiled.  Yes the rotor can be pointing at the #1 and not be on compression stroke on one of those times.  I use a remote starter button to turn the engine over quickly enough to check for compression on this test when I am by myself.  Remember the crankshaft gear is half the size of the camshaft gear and that compensates for the four stroke/two revolutions per firing of each cylinder.  Joe-JDC
Posted 7 Months Ago
Posts: 3.7K, Visits: 497.8K
I never heard of the minus 25 degrees for initial setup.  Could you explain that to me.  I always put it on top dead center to start and it always worked (not a lincoln engine)
Joe-JDC (5/25/2025)
Posted 7 Months Ago
Even dead stock engines are typically factory timed to some degree value that is BTDC.  By the same token, a first start for any engine should always have a liberal amount of ignition advance before TDC to ensure an easy start.  I have found that 25° BTDC for the first fire up will guarantee an easy start.  As a general rule, that extra bit of ignition advance does not need much correction once the engine is fired up and the actual timing is set.  Having some extra ignition advance on the startup will not hurt the engine and in most instances will have the engine running cooler for that initial camshaft break in period.
With all that being said, he’s a link to a past thread on the subject.
http://forums.y-blocksforever.com/FindPost138330.aspx
B-rad
Posted 7 Months Ago
I was talking about the timing mark and pointer on the crank. Will that pointer and tdc mark line up even if its not on compression? Not rotor, since the distributor isnt even in yet. And the crank should turn ccw ?
As far as the distributor not going all the way down....
Is there a trick for lining up the intermediate shaft and distributor? If the shaft is against the wall how should i center it and keep it there?
Brad
1954 Lincoln Capri
Posted 7 Months Ago
B-rad (5/26/2025)
I was talking about the timing mark and pointer on the crank. Will that pointer and TDC mark line up even if it's not on compression? Not rotor, since the distributor isn't even in yet. And the crank should turn ccw ?
The damper TDC mark and the pointer will line up twice during the four cycles that it takes to make an engine run.  The four cycles take two complete revolutions of the engine to complete.  Looking at the front of the engine, the crankshaft turns clockwise.
On one of those line ups, the piston will be at TDC but the exhaust valve is closing and the intake valve is opening.  This would be the overlap cycle which is simply that period of time that both the intake and exhaust valves on the same cylinder are open.  The overlap cycle is not to be confused with the other four cycles required to actually make an engine run.
On the other line up, the piston will be at TDC with both valves closed.  It’s this second event that you want the rotor in the distributor pointing to #1 spark plug wire in the cap.
Another useful piece of information is that when #1 is at compression TDC, the #6 cylinder is at TDC but at the overlap cycle.  Likewise, when #6 cylinder is at compression TDC, the #1 cylinder will be at the overlap cycle.
As far as centering up the oil drive shaft, that should not be necessary.  Once you get the distributor part way down but it does sit squarely on the block yet due to the oil pump shaft not being in the correct orientation, you will need to bump or turn the engine over slowly until the distributor completely drops in place.  You may need to put a light downward pressure on the distributor housing to make this happen as gravity alone may not do it for you.  Once it has done this, then you can double check that rotor is indeed still pointing to #1 in the cap with the damper at 20-25° BTDC.
pintoplumber
Posted 7 Months Ago
Posts: 1.0K, Visits: 164.2K
paul2748 (5/25/2025)
Joe-JDC (5/25/2025)
That’s not a minus sign in Joe’s post, it’s got curly ques at each end.
DANIEL TINDER
Posted 7 Months Ago
Posts: 1.7K, Visits: 154.2K
Ted (5/25/2025)
Ted,
Re-reading your 2018 reply, concerning startup advance ‘leeway’, and ‘low’ compression’:
Would you likely consider your 20 degree BTDC recommendation a maximum with 10:1 static in a fresh rebuild (Isky E-4/centered)?
6 VOLTS/POS. GRD. NW INDIANA
