Initial timing
Posted By B-rad 7 Months Ago
Posted 6 Months Ago
Last Active: 4 hours ago
B-rad (6/1/2025)
This is as far as it wants to drop in. What do I need to do to get it down all the way?
Once you get the distributor in place but it does sit squarely on the block yet due to the oil pump shaft not being in the correct orientation, you will need to bump or turn the engine over slowly until the distributor completely drops in place.  You may need to put a light downward pressure on the distributor housing while rotating the engine to make this happen as gravity alone may not do it for you.  Once the distributor has dropped all the way down, then you can double check that rotor is indeed still pointing to #1 in the cap with the damper at 20-25° BTDC.
