Opinion on motor status 292
Posted By capelo 7 Years Ago
capelo
Posted 6 Years Ago
Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)Supercharged (612 reputation)
Posts: 279, Visits: 4.5K
Tomorrow I will start mounting the heads. I have bought a new set of ARP bolts from Mummert, it comes with an assembly sheet, but this one, both in the form of tightening and in force and order does not correspond to the previous one read by me here. What is the correct way to act?
capelo
Posted 6 Years Ago
sorry the tightening order if it is the same
Posted 6 Years Ago
For grade eight bolts on the Ford Y, I typically torque them 70# for the short bolts and 75# for the long bolts using oil on the threads.  I’ll bring them up in three steps being 35, 50, & 70/75.  Bringing the top row to 70 on the third step and then finishing them off at 75# works for me.  I’ll use a circular pattern starting at the middle and working outwards on each step.  Clockwise (CW) or counter-clockwise (CCW) will not make a difference.
9     5    1    4    8
10   6    2    3    7
Deviations in this work as long as the head bolts are tightened in steps and not to full torque from zero in one step.  If someone else has variations in doing this, feel free to chime in.
capelo
Posted 6 Years Ago
Ted (4/7/2020)
9     5    1    4    8
10   6    2    3    7
Thanks for the advice. The bolts are ARP I guess grade 8 and I have greased the threads like the washers the ARP assembly lubricant. Following that order and that pair is it necessary to repeat it three times as the paper says to seat the joints? I am using "The BEST Gasket"
capelo
Posted 6 Years Ago
Ted (4/6/2020)
capelo (4/6/2020)
Do you use any sealant here?
http://forums.y-blocksforever.com/uploads/images/ee59c80a-4972-42ce-8e68-b5ff.jpg
No sealant is required for the gasket.
Are you using a spin on oil filter?  If so, then the nut you show in the picture is not correct for the spin on oil filter plate.
about this commented?
this is correct?
Dave C
Posted 6 Years Ago
Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)Supercharged (250 reputation)
Posts: 101, Visits: 31.2K
Only thing I would add. If the engine isn't going back in the car the same day, I would come back after it sits over night pull the last number again. What I mean is torque according to what Ted said. Then next day pull that 70/75 one more time. You might be surprised. I have had mine be several pounds loose even using different head gaskets, Felpro, Cometic and even copper..
Do this prior to setting valve lash.
Anyway that is the way I do mine.
Dave
capelo
Posted 6 Years Ago
Dave C (4/7/2020)
Dave
Ok thaks 👍
capelo
Posted 6 Years Ago
Today I end it, it already looks like an engine. Intake and cylinder heads, tight.
capelo
Posted 6 Years Ago
Tomorrow I get with them
MplsMike
Posted 6 Years Ago
Last Active: 8 Months Ago
Posts: 204, Visits: 92.3K
The pictures of the engine are beautiful! How about some pictures of that awesome looking truck in the background?
MplsMike
'56 Parklane
Minneapolis, MN
