capelo
Visits: 4.5K
Ted (1/19/2020)
Be sure to check the retainer to valve seal clearance. You’ll want at least 0.060” more than whatever your net valve lift is expected to be. now there is a distance of 0.492 "
capelo (1/19/2020)
Ted (1/19/2020) Be sure to check the retainer to valve seal clearance. You’ll want at least 0.060” more than whatever your net valve lift is expected to be. how can I know the net travel of the valve to make measurements The math for calculating the minimum required distance is as follows: Lobe lift multipled by the rocker ratio plus 0.060” minus the valve lash. In your case: 0.320” X 1.43 + 0.060” – 0.020” = 0.498” minimum If going with 1.6:1 rockers then: 0.320” X 1.6 + 0.060” – 0.020” = 0.552” minimum More than minimum is always desirable.
capelo
Visits: 4.5K
Ted (1/21/2020)
capelo (1/19/2020)
Ted (1/19/2020) Be sure to check the retainer to valve seal clearance. You’ll want at least 0.060” more than whatever your net valve lift is expected to be. how can I know the net travel of the valve to make measurements The math for calculating the minimum required distance is as follows: Lobe lift multipled by the rocker ratio plus 0.060” minus the valve lash. In your case: 0.320” X 1.43 + 0.060” – 0.020” = 0.498” minimum If going with 1.6:1 rockers then: 0.320” X 1.6 + 0.060” – 0.020” = 0.552” minimum More than minimum is always desirable. Thanks Ted, good explanation, I will try to go to the maximum possible space
capelo
Visits: 4.5K
After adapting the valve guides, I am looking for new seals, they have to be 11/32 "x 0.500". Any suggestions for this? I have these two visits: ENGINETECH S2926 QUALCAST 3881045
For positive type valve seals, I use U.S.Seals Inc. For the 11/32” X 0.500” applications the part number is VS107V. https://ussealparts.com/catalogsearch/result/?q=vs107v
capelo
Visits: 4.5K
capelo
Visits: 4.5K
I screwed up, I hadn't measured accurately enough, it should be 11/32 "x 0.510". I'm sorry
capelo
Visits: 4.5K
I only see .500 "-.502" -. 530 ", could anyone fit in?
capelo
Visits: 4.5K
Ted (1/27/2020)
The VS107V seal is rubber lined on its inside and doing a rough measurement with a dial caliper on my end indicates that it may work on the 0.510” diameter guide. This may just require some oil on the guide and seal surfaces to help the seal slide in place. Here’s a picture of the seal dimensions page from the U.S. Seal catalog which may help you make a more informed decision if you want to use the #107 seal or possibly another.
Ted thanks for the information, I'm going to order a VS-107V game. I can have them in oil some time before. Looking at U.S. SEAL, I have seen this other seal, I can order both and see what happens. https://ussealparts.com/vs-vo3v.html
