368 Lincoln Build
Posted By martyk98 7 Years Ago
mjs
Posted 4 Years Ago
Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)Supercharged (217 reputation)
Posts: 84, Visits: 123.9K
I needed to replace the gear on my 368.  As i recall when I called my local parts store they told me it was the same as a 390 and they had one on the shelf.
http://forums.y-blocksforever.com/uploads/images/1d5b145a-1c57-4c0d-8bd1-fba5.jpg
martyk98
Posted 4 Years Ago
Posts: 160, Visits: 31.8K
http://forums.y-blocksforever.com/uploads/images/42fe05fd-0623-4c7c-a676-48b3.jpghttp://forums.y-blocksforever.com/uploads/images/45d8fe9d-9a05-4aff-bd6f-d6fb.jpghttp://forums.y-blocksforever.com/uploads/images/1ae934ec-d095-46ad-bd85-2c90.jpghttp://forums.y-blocksforever.com/uploads/images/e66a6cd3-c8ae-41fb-9369-a962.jpgThe housing is the problem. The diameter of the housing won't allow the distributor to set down in the hole of the block. Then the base of the housing is too large to properly seat on the block. There is a small machined flange on the block  that needs to marry with the base to finish the install. We had the right distributor to send them, we had it running on the engine previously. I sent it back today so we'll hear something back next week.
FORD DEARBORN
Posted 4 Years Ago
Last Active: 2 Weeks Ago
Posts: 852, Visits: 113.5K
Glad you found the problem   I have on hand here both a Ford and Lincoln Y-block distributor. The diameter of the upper flange that positions the strib in the machined undercut in the block measures 1.750".  The 2 lower pilot areas that enters the hole in the block measures 1.495".  These are the measured dimensions of the Lincoln and Ford y-block distributor so both housings are dimensionally the same.   And what's more, great to see you have recovered well and back in the engine game........................
martyk98
Posted 4 Years Ago
Thank you. I sent the unit back on Saturday. He must have grabbed the wrong housing. My measurements on the one he sent me do not match yours, mine are larger. Thanks for the information.
martyk98
Posted 4 Years Ago
http://forums.y-blocksforever.com/uploads/images/b5993d87-d060-4931-b35c-55b7.jpghttp://forums.y-blocksforever.com/uploads/images/8cb7b047-e100-41ae-9ff9-031e.jpghttp://forums.y-blocksforever.com/uploads/images/5a1cc334-f432-40a9-8fa8-37bb.jpgWell.... It was more than just the housing. I sent it back and got it back without the cap. Put it in the block and it didn't fit. The tip of the shaft where the oil pump shaft enters was wider than the hole in the block. I managed to take it out and set it up so I could use some 80 grit on the shaft while I spun it with my drill. Within 10 minutes I had the shaft sanded down where it fit nicely in to the block hole. Then the next problem..... When I bolted down the distributor to the block the shaft quit turning because the gear was pressing too hard on the block down below where the shaft tip connected to the oil pump shaft.  Back to FBO for modifications, again.  There are several lessons to be learned here, let me list them. Pic 1 is the hole in the block that was too small. Pic 2 is the sanded shaft to make it fit. Pic 3 is the bottom of the gear that bites down on the block when bolted down.
1-take plenty of pictures and measurements of your distributor
2-if you're the company that is making the changes, do the same before you tear it apart and modify anything.
3-never assume all the stories about distributors being swapped from one block to another are always true.
4-the 368 Lincoln/Mercury block is an ODD DUCK.
I don't blame FBO entirely for all the issues, my odd duck was something they haven't seen very much of. BUT, their lack of following #2 has resulted in some frustration that surely could have been avoided.
I'm also sure that they could do a wonderful job on a more common distributor.
FORD DEARBORN
Posted 4 Years Ago
Sorry to hear about the additional problems.  Hard to see the internal 1/4" hex inside the shaft end but it is there isn't it?   From my limited dealings with Lincoln Y-block distributors, the dimensions are the same as that of the Ford distributor except for the gear.  Since it appears the gear is binding on the machined surface in the block, then it is not set to the spec of 4.991 to 4.996 shaft extended down as shown in the Ford manual. The thrust should be minimum .021" with .030" acceptable.  Also, make sure the internal 1/4" hex as mentioned above is indeed deep enough to allow the oil pimp drive shaft to penetrate as it should.  Is the camshaft installed in the engine?  If not, try installing a Ford Y distributor if you have one on hand to see how that fits in there.    As stated in one of my earlier posts:  I am at this time running a 1957 368 tach drive distributor in a 1964 Ford Y-block after changing only the gear. My point is the Lincoln Y and Ford Y distributors are dimensionally the same except for the gear. At least 1957 on.
martyk98
Posted 4 Years Ago
I hear you. I think the issue is when they modified the shaft to fit the Pertronix base unit the made the shaft too long. Because I had to send the unit back to get it to fit my block, the length of the housing might be a little off from the stock height which could have thrown other measurements off as well.  Eventually we will get this right. Their communication with me has been excellent. In no way are they ducking the issue and are standing behind their work. BTW, the hex shaft fits well.
martyk98
Posted 4 Years Ago
That's one thing about being retired, you don't have to be in a hurry. We got the distributor back, is was their mistake. All fixed and installed. My partner and his wife picked up COVID somewhere and are hiding until his wife feels better. The shots have saved them from being really sick. We'll get the 368 running again soon. Dialing in 8 Webers is time consuming.
Posted 4 Years Ago
Last Active: 10 hours ago
8 Webers or 4 two-barrel Webers?
martyk98
Posted 4 Years Ago
4 two barrels. My partner had COVID so between crummy weather and him we will be on standby. He's working on a 54 Corvette at the moment. Anyone know where we can get an oil pan, let me know. The one in the car has extensive damage. June 20, got the oil pan repaired by a local pro. 60 degrees 2 days ago, 85 this coming Saturday.?????/
