TBird Multiple Carb Options
Last Active: 11 hours ago
How about a 2X4 intake with two barrel carbs.  Carbs could be Holley or Ford/Autolite.  Plenty of room for 2V carbs and would expect it to be very drivable.
http://forums.y-blocksforever.com/uploads/images/2ee270e3-8cd8-4013-bc65-f7d8.jpg
http://forums.y-blocksforever.com/uploads/images/e5699bc1-1130-44d3-89ae-72df.jpg
Posts: 1.2K, Visits: 285.6K
What a great idea.  I'll bet it would run good too.  Fabricate some linkage from an FE motor and you are good to go.  I suppose you would be running on both carbs all the time?  1950s Cobra style?
Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)Supercharged (4.7K reputation)
Last Active: 12 hours ago
Posts: 2.0K, Visits: 306.5K
What would the benefit be? If going that route, you may as well mount a MUMMERT/BLUE THUNDER intake with a suitable HOLLEY and go for performance shouldn't you?
Probably difficult to fit under the hood of a T-Bird  since adapters, which probably are not already made, are required.  Plus a custom air cleaner would have to be made.  Expensive project.  It would look neat but I agree, at that point, single 4 is the way to go.
Florida_Phil.  Consider the intake set-up shown and described by this eBay seller.  Unique, sorted-out, complete, and set-up for a 'Bird.  Currently listed on eBay.
Click the link below.
https://www.ebay.com/itm/Ford-Y-Block-Dual-Y-H-Carb-Interceptor-Marine-Intake-vintage-speed-boat-rat-rod/253992016608?hash=item3b231a9ae0:g:vYsAAOSwnh9b33KP:rk:13:pf:0
Posts: 1.9K, Visits: 195.0K
Here’s a link to famdoc3’s post about dual 2 barrel injection units on a 2x4 manifold.  About half way down.
http://forums.y-blocksforever.com/Topic135011.aspx#bm135266
Lots of options will work if you can get the hood to close.  I see a lot of those marine intake systems on EBay. That would fit under a TBird hood with ease. I think they look ugly, especially with the two radiator intake hoses required.
Pete 55Tbird
Posts: 721, Visits: 93.2K
Phil, since your goal seems to be "eye candy" above all else. Go full tilt, add a 4-71 and CUT A BIG HOLE IN YOUR HOOD and be done with it. Pete
Posts: 3.7K, Visits: 498.2K
he wow factor, just like 2 4's or 3 2's.
KULTULZ (11/24/2018)
http://forums.y-blocksforever.com/uploads/images/ac971095-4907-44df-8e40-23e3.jpg
