Dragster Engine
Posted By Cliff 8 Years Ago
Cliff
Posts: 908, Visits: 14.0K
You got it, going to run steel rockers this time, I see you are running ECZ-C heads, what's up, are you having better luck with them, better than the G?
The Dove rocker arms became problematic.  Harland Sharp have been great.
LordMrFord
Posts: 687, Visits: 9.3K
Cliff (5/17/2018)
If I remember right, we put stock balls to alu rockers.
We got no spare G heads so we have to live with what we have.
Our N/A spare engine (11.8s) have those but got no titanium valves or flame ring groove.
Head itself never had a mechanical problem, but maybe some other heads might be more powerful but we dont know.
Hyvinkää, FI
Cliff
http://forums.y-blocksforever.com/uploads/images/4487c8cf-cf4c-4883-9d1f-1075.jpg
Ok, the drivers side head just touches the piston, a little more grinding (this is a lot of work)
http://forums.y-blocksforever.com/uploads/images/c5bd7ee6-f46c-4768-b1e2-5ba6.jpg
Cliff
http://forums.y-blocksforever.com/uploads/images/30a7ed85-2f0c-4d65-a352-b122.jpg
http://forums.y-blocksforever.com/uploads/images/2b7316a1-2315-4f44-b2e0-2ec2.jpg
Now the right head done (3 spots).
Cliff
Oil pump done, this is a 1961 Ford reman, I took it apart and increased the spring pressure (spacer) nothing else done, I had to make the shoulder bolts out of longer bolts (stainless allen), this holds the pump better.
http://forums.y-blocksforever.com/uploads/images/2279037c-13cc-4ccf-abd3-08f6.jpg
http://forums.y-blocksforever.com/uploads/images/41c4ba43-44a6-475e-88b0-6eca.jpg
Cliff
Last check for clearance, white grease on pistons, head installed, engine turned over, No Touch (: .http://forums.y-blocksforever.com/uploads/images/9c40450a-3021-4380-bbad-2e56.jpg
Cliff
Drivers side head needed more work, this is going to be a tight engine .039 head gasket, piston .010 out of the hole (.029 deck clearance)http://forums.y-blocksforever.com/uploads/images/1b5b07e0-f1fb-476e-82bd-226c.jpghttp://forums.y-blocksforever.com/uploads/images/29320263-0f99-4aa2-a961-1442.jpg
Cliff
New problem, pistons hit the spark plugs (closed the gap) found shorter plugs that fixed it (AC R86T), have to look at everything on this engine
Cliff
More stuff, here's the the rocker arms I'm going to use, real FoMoCo shaftshttp://forums.y-blocksforever.com/uploads/images/d5c43cdc-4668-4240-8308-ec68.jpghttp://forums.y-blocksforever.com/uploads/images/c733656e-0ba2-4be9-9cd1-33db.jpghttp://forums.y-blocksforever.com/uploads/images/c49fe886-f7e7-443a-9480-fd59.jpghttp://forums.y-blocksforever.com/uploads/images/1c7fe147-38b7-4148-9211-c6f0.jpg
