Dragster Engine
Posted By Cliff 8 Years Ago
Posts: 7.6K, Visits: 206.1K
Randy’s dragster was a solid 8.90 performer with the 762HP BBC engine and running on a throttle stop.  The previous owners had tried a much higher horsepower 615” BBC and the dragster chassis simply had trouble planting itself after 700 feet.  Randy’s Y-Block had the same issues with traction at the top end of the track.
Cliff
Posts: 908, Visits: 14.0K
Working again, had to remove a little metal from the chambers.
http://forums.y-blocksforever.com/uploads/images/33937272-f283-453e-ac1b-6a09.jpghttp://forums.y-blocksforever.com/uploads/images/097e01f0-71a5-44df-9d80-ef64.jpg
Cliff
Next head, some of this stuff is SHARP.
http://forums.y-blocksforever.com/uploads/images/97753027-8793-4543-875e-dc77.jpg
http://forums.y-blocksforever.com/uploads/images/e3304555-f353-4723-b06c-344d.jpg
 http://forums.y-blocksforever.com/uploads/images/648df197-5aec-4cb5-a4f6-e177.jpg
Posts: 3.7K, Visits: 323.8K
OUCH!!!!!!!!!! Your  Block bit you!  Those big intake valves look awesome, however to my untrained eyes they look to be shrouded pretty seriously.  I hope I'm wrong.
Cliff
Hi, John Mummert did the ports and the chambers, they flow 245@.500@28" and 205@.500@28" I did some changes and did not run them on my bench.
prosycamore
Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)Normally aspirated (39 reputation)
Posts: 18, Visits: 23
Got any new updates?
Cliff
Needed to catch up on other work, will be back on it this weekend, will be rechecking, piston to valve, piston to head, valve to block clearance, then modify rocker arms for ball and ball push rods (5/16 ball, cut passage for oil to the top ball)
Thanks for the interest
Why the change for the pushrods?
Cliff
I do things to solve problems I have had in the past (push rods ending up in the valley), this may or may not be of any value but I try.
LordMrFord
Posts: 687, Visits: 9.3K
alu rocker got too big ball problem?
Hyvinkää, FI
