Visits: 206.1K
Are you using heat to help preform the lexan?
Visits: 14.0K
Yes, this stuff is strong, when I heat it hot enough to make it pliable and try to shape it it cools fast and gets hard (about 5 seconds). I'm going to try to form it cold (?) I can bend it in a metal brake (cold) and it bends just like metal.
Visits: 23.3K
If you use a Benzene torch and keep it moving across the lexan, it will not cloud up. Run the benzene across any cuts, and the edges will smooth out and come clear. Just don't over do the heat in one spot. It works on other acrylics, also. Joe-JDC
Visits: 14.0K
Visits: 14.0K
Visits: 14.0K
Merry Christmas everybody!
Posts: 1.1K,
Visits: 58.8K
You are doing some very interesting work on this Setup. I've been following along and can't wait to see what's next. Good job Clif!
Visits: 14.0K
Thanks, this manifold is killing me, and I got sick for a week.
Visits: 23.3K
Visits: 14.0K
That's a Idea, however I think I got it.
