Visits: 23.3K
Just curious what the manifold will be going on? The dragster? I have worked, modified, tweaked, built, ported, even made acrylic spacers, and I am trying to figure out exactly what your intensions are at this point. Not criticizing, just trying to imagine your intended final product. If you are making a single 4V, or something else, why not use one of Mummert's gaskets to get your dimensions for your manifold bases? They are unidirectional, and a bit larger than the Fel Pro or Best gaskets. Watching with interest. Joe-JDC
Visits: 14.0K
 Hi Joe, this is going on my dragster engine, it will mount a Hilborn 4 port 3" short injector, this is Lexan (polycarbonate), I've worked on this for a long time
Visits: 7.5K
So when is the dyno date Cliff? It looks like your down to the last steps.
Visits: 14.0K
Going to run it in the car first, working on the intake runners today, I'm afraid to put it on a dyno and have it top out at 300 HP.
Visits: 14.0K
Visits: 14.0K
Here's what happens if you don't balance your engine (funny) https://www.youtube.com/watch?v=dq6T5BojXc8
Visits: 14.0K
Visits: 73.6K
Your doing some quality work there Cliff. I've watched your build from the start and I believe it will be a master piece.
BurnsRacing981@gmail.com
Visits: 14.0K
Thanks Charley, one of the bolts that hold the shield to the rear of the transmission stripped when I tightened it (3/8 allen), I'm going to helicoil it in the car with out pulling the transmission apart (I hope)
Visits: 14.0K
What am I doing? well the intake manifold is not cooperating, having a hard time forming the Lexan into the shapes I want.
