Visits: 14.0K
Visits: 14.0K
Small amount of work tonight, had to rework the pinion support, it was crap, it's finished in 80 grit and cleared
Visits: 14.0K
I finished the pinion support before, however I did not try to fit it, it came off the car so I only cleaned it up, the bolt holes were off, so 2 hours later and a refinish, it's good to go, guess I should fit all parts first, even if they came off the car.
Visits: 14.0K
 What did I do today, well refinished brake calipers (long time), took apart shop air compressor (bad valve), I'm going home, picture tomorrow.
Visits: 14.0K
Brakes done, all new stainless hardware (aircraft surplus), all steel parts black oxide finished, all stainless parts polished (brush finished), next the lines and fittings (most refinished and    ready to install)
Visits: 14.0K
Fitting the firewall today, trimmed up the edges, profiled the corners, fitting the electronics.
Visits: 14.0K
Fitted, now starting to finish, 80 Grit and clear
Visits: 14.0K
Firewall done
Visits: 14.0K
Making the center firewall (between battery and cockpit)
Visits: 14.0K
What I did today, 1 put rings in my shop air compressor, fitted the firewall, now to finish and paint (80 grit and clear)
