Visits: 14.0K
Just about to install this, Strange aluminium case and spool, 4.30 pro gear
Visits: 14.0K
Ok, done for today.
Visits: 113.5K
Is that joint at the pinion a CV joint? Even though the housing is aluminum, the milk crate looks quite stressed. Getting close to rolling and all looks super!
Visits: 14.0K
That's a drive coupler, yes that thing is heavy.
Visits: 14.0K
Visits: 14.0K
Added 1 more lift it's huge!! 3 car, 2 inches from the roof.
Visits: 14.0K
Starting work today, repairing damaged caliper bracket
Visits: 14.0K
More work, roughed in the firewall, more work on the rear axle (cleaned and checked hardware) 1 lug stud needs replacement (not true when run on the lathe) can not buy this stud, so I bought one from Mark Williams that I will have to   cut down.
Visits: 14.0K
A little more work tonight
Visits: 14.0K
