Posts: 3.0K,
Visits: 8.7K
Chuck, I grew up in Ohio, about 25 miles from Arfons shop.
Y block Billy
Posts: 1.6K,
Visits: 5.2K
Ron, Stopped at my motor guys last night to bring him some parts, he is starting his own shop and talking to him he mentioned when he gets his dyno set up he supposed to dyno a Y block from Pittsfield with a supercharger on it, I said I know whos motor it is, I may go there and help him set up his dyno and definately want to be there when it is tested!
Rono
Posts: 1.3K,
Visits: 80.0K
Billy; Sorry I didn't respond earlier, I was traveling. I spoke with Steve before I left for CA. He is good friends with the guy that runs Central Maine Mustang in Pittsfield and who I got his name from. We talked for a while about dyno testing the motor and while I would love to have you guys help with that, he said that he wouldn't have his dyno room set-up for 6 months. I was hoping to get it done sooner than that. There is a guy in NH that has an engine dyno who I spoke with yesterday. He is partners with the machine shop that did the block machining for me. He would like to dyno the motor for me, but never did a Y Block and isn't sure if his adapter plate will fit my bellhousing. I e-mailed him the measurements of the bellhousing yesterday and I may need to buy John M's T-5 adapter plate first. Anyway, I would rather play you and Steve if possible to get the motor dynoed if we could get it done this summer. Rono
Ron Lane, Meridian, ID
Y block Billy
Posts: 1.6K,
Visits: 5.2K
I just brought a block up to their new shop they needed for a 390 rebuild, things look a little ways away but Steve left his last post and is working there full time so it may come together quicker than thought, We Hope! Nice looking setup and the other partner is a sharp Ford Man all the way!
ejstith
Visits: 1.0K
Damn ! That's purty !!
E.J. in Havana FL
Rono
Posts: 1.3K,
Visits: 80.0K
I had to travel from Maine to NH to get my first round of dyno testing done yesterday. I allowed 2 days for this, but it turned out not to be enough. The dyno operator never did a Y-block and had to make special spacers for the bellhousing to adapt to his dyno. This took a long time and he worked long into the night. The next morning, around 11:00 Am, I was happy in the fact that the motor fired right up and ran well. We set the initial timing at 13 degrees advance and I re-curved the MSD distributor for a maximum of 38 degrees advance at 2,400 RPM. The dyno room was in a converted barn and even with 2 big exhaust fans and a big blower fan on the motor, temperatures reached almost 100 degrees and 60% humidity. We broke-in the motor with the belt and carb hat off the motor, but he never monitored the mass air flow going into the carb. He said he didn't think it was needed. Anyway, I found out what I needed to know. The motor held together and ran great, but fell short on the horsepower. The data seemed to show that the 650 double pumper was a little too small and the stock 57 EDB exhaust really killed it. By the time we got to this point, it was 5PM and since I only had a hotel room for 1 night and had almost a 4 hour drive ahead of me, I decided to pull the plug and stop the testing. We could have gone up a couple of steps with the secondary jets from #76 to #78, but I really didn't have the time and didn't think I would gain that much given the carb and exhaust limitations. The blower added 75 HP over the same RPM range as when the motor was run without the belt attached. We only ran it up to 5,000 RPM when we got almost 300HP, but was still climbing. The torque peaked at 360 ft/lbs @3,200 RPM. At least now I know the motor is good to go into the 37 Coupe. I'll get some good headers and bump the carb up to a 750 double pumper. Maybe by then I can get with Y Block Billy and get the motor dyno tested again in Maine this time or get the coupe finished and have a chassis dyno test done. Rono
mctim64
Posts: 2.4K,
Visits: 5.0K
Good job Ron! I think you will see some improvement in the numbers with a few changes. Great starting point though.
Congratulations on making a number of successful dyno pulls without engine problems. The first time for firing any engine is always with trepidation as there are a myriad of problems that can come to the forefront. Thorough preparation in your case has obviously paid off.
Rono
Posts: 1.3K,
Visits: 80.0K
Thanks for the kind and encouraging words Ted and Tim! I took a "Flip" video of the dyno pull and I have attached the link below. I don't know if it will work because I have never tried this before. http://flipshare.theflip.com/EN_US/5.12/Partners/Other/ShareVideos.htmRono
slick56
Last Active: 3 Weeks Ago
Visits: 4.5K
Hey Rono, great engine! The link didn;t work for me (google chrome), will try explorer a little later. Did you get your '37? If so, howz that coming on?
South Australia
