Turbocharged 292 stroker!!!
Posted By Hutz 292 15 Years Ago
Posted 14 Years Ago
Have your machinist be careful not to machine the pistons too much. You'll need at least .200'' wall thickness left on the piston tops. And that's pushing it at 18/20 #.
Talkwrench
Posted 14 Years Ago
Posts: 898, Visits: 23.2K
Consider O ringing the heads [or block] and use copper head gaskets as well when you re-install.
Hutz 292
Posted 14 Years Ago
Posts: 228, Visits: 1.1K
What brand or company can I purchase copper head gaskets?  I haven't been able to find a source for different head gaskets.  If you could let me know that would be great.  It looks like if you shave just the dome off the piston it will not affect the thickness of the piston.
Talkwrench
Posted 14 Years Ago
You will have to have them made.. Seppo has had some made but he is at the other end of the earth like me. There was a post quite recent about them. Ted, Tim or John may have a contact.
Posted 14 Years Ago
Copper head gaskets were advertised in YBM about a year or so ago. Maybe someone here can zero in on what issue?
glrbird
Posted 14 Years Ago
Posts: 616, Visits: 7.1K
http://www.y-blocksforever.com/forums/Topic71011-3-1.aspx
here is the info on copper headgaskets.
Gary Ryan San Antonio.TX.
Hutz 292
Posted 14 Years Ago
Wondering if the Hollow Heads could get some copper gaskets?  John is almost done with my heads.  If you have some cut I will buy them if not there is a shop in town with a cnc machine to cut them but if you could get me some that would be great.  Have you used many of them yet and how have they held up?
Hollow Head
Posted 14 Years Ago
Posts: 1.0K, Visits: 3.8K
We can deliver plates for you. Just tell us how thick you want. Our first test for those plates will be at the end of June, cause our new bottom end has had some delays. So, we have no experience yet.
Hutz 292
Posted 14 Years Ago
I am not sure exactly what thickness I would need.  I would guess whatever a crushed gasket thickness would be.  Have you used any yet?  Do they require more torque and seal good?
Hutz 292
Posted 14 Years Ago
I got my pistons back from being milled down and put back in my engine.  They look great and should make a much better combustion chamber.  My heads should be here hopefully monday.  I also ordered a Borg Warner S3008SX-66 turbo charger which will support up to 800 whp.  Should not run out of air this time.  Should have it back together by end of the week.  My old head gaskets also showed no signs of compression leakage what so ever.  They had about 1200 miles on them with 8-10 lbs of boost.  Will update on any progress.
