Turbocharged 292 stroker!!!
Posted By Hutz 292 15 Years Ago
Posted 13 Years Ago
Posts: 4.6K, Visits: 39.4K
Looking good, again. I'll bet this time there will be a lot of checking around the fuel linkage! w00t
I bought a new Fairlane back in 69 and drove the s(&^% out of it. I was lucky to get one of the dealer prepped 428 Super Cobra Jet, Fairlane Cobra's. Lightened with a 4:30 Detroit locker and 4 speed. It was everything they say it was. Super fast car. 6 months later me, the wife and the Cobra were all transferred to Germany. Now that there was FUN! Conrad never saw it coming. But thats another story. Chuck
Hutz 292
Posted 13 Years Ago
Posts: 228, Visits: 1.1K
Well we the screaming y-block for the first time in its new home. We jsut have to finish the exhaust and intercooler plumbing and it's ready for a test drive. Hope this video works I was having trouble uploading it.
https://www.facebook.com/photo.php?v=497950446926789
Hutz 292
Posted 13 Years Ago
Hey everyone just thought I would post a pic of my dad's 68 Torino. It doesn't have a Y in it but I would think you would all appreciate a nice old ford. I has a built 302 with Edlebrock Performer aluminum heads, performer intake, cam and 150 shot of Nitrous. It's a great joy driving this car.
Hutz 292
Posted 13 Years Ago
Hey everyone haven't posted for a while I have my diff installed but had to put off the truck for a while had to much work to do.
Hutz 292
Posted 13 Years Ago
Well I have my computers wired in and my differential is supposed to be here tomorow. I will post some pics if it makes it. I also have a new intercooler on its way. The piping will go in the sides and come out the middle straight to the throttle body. We are having a car show and dyno day at the shop May 18th and I am hoping to have this running by then. I also ordered new front bumper and side skirts and a roll pan for the rear bumper. Hopefully in the next couple of weeks we will make some serious progress on this project since the weather is finally above freezing!!!
LordMrFord
Posted 13 Years Ago
Posts: 687, Visits: 9.3K
Hutz 292 (3/24/2013)
If I remember I am running around 6 degrees at 24 psi. We are at 19 degrees @ 0 vacuum or 90 kpa.
Those advances sounds pretty low. I have seen couple of turbo maps where 250 kpa / 3000 rpm advance are 14-19 and if I understand right, 100 kpa / 3000 rpm advance should be close to 36 with iron headed Y with or without chargers.
Hyvinkää, FI
Hutz 292
Posted 13 Years Ago
Got some updated pics from the project. Nice front view of the setup and I don't think I have posted a pic of the new truck yet.
This is the new home for the Y!
My E4OD with the new 2wd output shaft, fit like a dream.
I have my new 2in drop spindles and rear drop shackles installed. I have to wait until my new diff shows up so I can have a driveshaft built. Only thing we will have to build will be the brackets for the shocks to bolt up to. The 12in disc brakes will be installed and my brake cables should work. I already ordered my wheel adapters so we can use the wheels and tires I just bought for my other truck since they have a total of about 5 miles on them!
Hutz 292
Posted 13 Years Ago
The feed oil comes from the oil port back by the oil filter. The inside of the block has been drilled out so the oil will pass right throuh aluminum block. Prior we just had a 4 way block at the oil feed posrt on the engine and ran two lines from there. This will look nice with two braided lines coming from it.
Hollow Head
Posted 13 Years Ago
Posts: 1.0K, Visits: 3.8K
Eeehh... really don't get the point with that fuel pump block off / oil distributor thing. You still have to hook it to oil gallery from somewhere... This is how we did. Fuel pump block off plate is just a block off and oil feed comes from the gallery and splits to two. That system is still in use though that picture is from early twin turbo days Laugh.
http://forums.y-blocksforever.com/Uploads/Images/1efcce64-30a9-496c-9356-5978.JPG
http://forums.y-blocksforever.com/Uploads/Images/1ab035ca-280a-488c-a8a1-6c7a.JPG
Posted 13 Years Ago
I like the fuel pump block off. Mine doubles as a fuel line bracket for connecting the flex line from the frame.
