yblock55
Visits: 273
Something special Y project going on this winter ? I have to deal with my oil leak on the engine and the rear end. The engine haves a leak on the crank case vent house, and i have a leak around the oil pump/Bottom end off the converter house. I think this leak is coming from the valley cover under the intake. Robin Norway
Finish my wire harness / instrumentation upgrade which was started about 2 years ago. Get the truck to hook and ready for test and tunes in the spring. After that, it's necessities, rust repair.
MarkMontereyBay
Visits: 3.8K
For my Tbird, Granada disc brake upgrade, T-5 Conversion from the Fordo, and a lot of detail stuff; cleaning, polishing and some re-chrome work. Goes to the muffler shop to replace the Magnaflows in the morning. Not sure what will be the replacements...have thought about Supertrapps. I am working on a plan for lowering the front. The Granada spindles will drop it about an inch or so. The problem is the aluminum heads and intake, Sanderson headers took some weight off the front and it sits higher now. I think I cut the front coils for a 1 inch drop years ago when I replaced them, not sure. The Fatman 3 inch drop spindles are too low for my taste and worry about fender clearance on parking lot/driveway bump tight radius turns. Plus they want nearly 600 bucks for them.
57 Black Tbird 312/auto
Glen Henderson
Posts: 1.4K,
Visits: 7.5K
Getting my 57 Custom back on the road.
And getting some decent brakes on the Falcon.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Last Active: 10 hours ago
Visits: 38.5K
I'm hoping to get the 292 in MoonShadow this week. If it will ever quit raining! (sorry Texans) That done I'll put the vicky back in the trailer for the winter. With a little luck, and a lot of rearranging I'll be able to get the roadster in the garage. If not it's off to storage too. Either way I won't have much room to do any work. So I guess I'll just piddle around on small stuff and EBAY. Someday I have to clean out my garage! 2car unit is currently a no car! Chuck
texasmark1
Visits: 2.7K
Finish the front door panels for my 57 Fairlane and helping son with his recent first car purchase, the 63 Mercury Monterey. Mark
slumlord444
Visits: 137.8K
Geting the toploader in the T-Bird and working with the original handle on the Hurst shifter. Have body stripped and repainted. New cam for the engine and Mummert heads if I can come up with the cash and he can come up with the heads. Busy and expensive winter coming up!
JPotter57
Visits: 1.2K
Getting my `57 Custom back together and on the road for the first time since it last ran in the late 60's...Can't wait! Have a 292 and 4 speed for now, will be getting a 312 and either a 4 or 5 speed later. So, engine/trans install, wiring, paint, and last will be upholstery. Already have rear and brakes done. Would be thrilled to have it at Columbus next year, at least with the 292. The finished 312 would be a hat trick.
James Potter `57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
46yblock
Visits: 7.8K
Assemble my 312, put floor pans in the '55 wagon, see if the wagon's 272 will start, pull it either way, find out what the noise maker is on a 292 on the engine stand.
mctim64
Posts: 2.4K,
Visits: 5.0K
Building engines for both Jake and Elwood also getting together a tow rig that can haul my camper and pull the Uni to Bonneville & Elmo.
