So, whats the project this winter Y guys ?
Posted By yblock55 14 Years Ago
Canadian Hot Rodder
Posted 14 Years Ago
Posts: 691, Visits: 1.3K
Hopefully will be able to change old Vicky from an FMX auto to a T-5  manual! My wallet will let me know if this will happen!  LOL
yblock55
Posted 14 Years Ago
Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)Turbocharged (65 reputation)
Posts: 65, Visits: 273
Way cool guys!
I wish i could have moved to usa for a year ore two. Just to see all your y projects and see some shows around.
Is it still drag racing on bonneville salt flat ?
Rono
Posted 14 Years Ago
Posts: 1.3K, Visits: 80.0K
Hopefully I'll be able to complete my 331 cu.in. supercharged motor that I started 3 years ago. Moving from Idaho to Maine a little over a year ago stopped me cold. But after working on building a new shop which I just moved into last week, I'm on a roll. Got my VS-57 back from John Erb now modified to a SN-93 with high output impeller and extra heavy (street) spring pack. I've got John's stroker kit, ported and polished 471 heads and a C2AE block that will go out for machining this winter. I'll keep you posted with pic's of the build.
Rono
Hollow Head
Posted 14 Years Ago
Posts: 1.0K, Visits: 3.8K
Going back to twin turbo setup and more strength to bottom end Smile.
mctim64
Posted 14 Years Ago
Posts: 2.4K, Visits: 5.0K
Building engines for both Jake and Elwood also getting together a tow rig that can haul my camper and pull the Uni to Bonneville & Elmo.
46yblock
Posted 14 Years Ago
Posts: 1.2K, Visits: 7.8K
Assemble my 312, put floor pans in the '55 wagon, see if the wagon's 272 will start, pull it either way, find out what the noise maker is on a 292 on the engine stand.
JPotter57
Posted 14 Years Ago
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 144, Visits: 1.2K
Getting my `57 Custom back together and on the road for the first time since it last ran in the late 60's...Can't wait! Have a 292 and 4 speed for now, will be getting a 312 and either a 4 or 5 speed later. So, engine/trans install, wiring, paint, and last will be upholstery. Already have rear and brakes done. Would be thrilled to have it at Columbus next year, at least with the 292. The finished 312 would be a hat trick.
James Potter
`57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
slumlord444
Posted 14 Years Ago
Posts: 1.2K, Visits: 137.8K
Geting the toploader in the T-Bird and working with the original handle on the Hurst shifter. Have body stripped and repainted. New cam for the engine and Mummert heads if I can come up with the cash and he can come up with the heads. Busy and expensive winter coming up!
texasmark1
Posted 14 Years Ago
Posts: 650, Visits: 2.7K
Finish the front door panels for my 57 Fairlane and helping son with his recent first car purchase, the 63 Mercury Monterey.
Mark
Posted 14 Years Ago
Last Active: 10 hours ago
Posts: 4.6K, Visits: 38.5K
I'm hoping to get the 292 in MoonShadow this week. If it will ever quit raining! (sorry Texans) That done I'll put the vicky back in the trailer for the winter. With a little luck, and a lot of rearranging I'll be able to get the roadster in the garage. If not it's off to storage too. Either way I won't have much room to do any work. So I guess I'll just piddle around on small stuff and EBAY. Someday I have to clean out my garage! 2car unit is currently a no car! Chuck
