Street engine build
Posted By YRAG32 14 Years Ago
YBLOCKMERC
Posted 13 Years Ago
Last Active: 8 Months Ago
Posts: 194, Visits: 20.6K
Very cool Hi-Boy. It's hard to believe you'll be covering up that gorgeous Y though.
Marc
'54 Merc ragtop
Pt Townsend, WA
      http://forums.y-blocksforever.com/uploads/images/e83cf74f-a3dc-4e1a-a928-8075.jpg
YRAG32
Posted 13 Years Ago
Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)Normally aspirated (43 reputation)
Posts: 31, Visits: 496
Thank you all for your kind words, the idea for the car is ''bare minimum'' on the out side but full detail under the hood, cheers oggie
y block powered mudshark or atomic
YRAG32
Posted 13 Years Ago
Can anyone give me a drawing or detailed advice on machining a stock flywheel? I'm using a after market hi torque starter so i'll tig the ring gear to the flywheel, but i want to lighten it up a bit. Thanks oggie
YRAG32
Posted 13 Years Ago
What are the best spark plugs for the Mummert heads?
aussiebill
Posted 13 Years Ago
Posts: 1.8K, Visits: 11.4K
YRAG32 (2/3/2012)
Wayne, there may be many depending on peoples ideas, most of the lightened ones i,ve seen have just had the front machined off, most ive seen are from boats.Smile
 Down Under, Australia
marvh
Posted 13 Years Ago
Posts: 513, Visits: 16.7K
YRAG32 (7/24/2012)
I am running NGK BCPR6EIX-11 (this number I converted from the Champion number John listed with the heads info) along with MSD distributor, MSD box, Mummert heads and intake with fuel injection.
NGK's.... the higher the number the colder the plug.
marv
Posted 13 Years Ago
Last Active: 4 days ago
Here are the Autolite numbers I use for 14mm, ¾” reach sparkplug applications.  This includes the aluminum Mummert heads.
For compression ratios from 9.0:1-11.0:1, Autolite 3924.
For compression ratios from 11.0:1-13.5:1, Autolite 3923.
For compression ratios from 13.5:1-15:1, Autolite 3922.
On the Autolites, the higher the number, the hotter the plug.  As a general rule, U.S. made spark plugs get hotter as the number increases while offshore or foreign sparkplugs have cooler operating ranges as the number increases.
YRAG32
Posted 13 Years Ago
Thank you all for the info, Bill the pistons arrived today thanks for your effort, your 292 slugs will be in the post asap, thanks oggie
YRAG32
Posted 13 Years Ago
First run on the Dyno today 241 hp and 272 f/lbs @5000 rpm, engine guy said it sounded sweet! But plugs in 1&5 and 3&7 are dirty (sooty) while plugs 2&6 and 4&8 are fine! I'm using a stock Ford 2X4 intake with 500 edelbrocks, any clues? He thinks it maybe bad mixing cause there' no plenum chambers under the carbs. Hes sure the hp will increase after this is solved.
cheers oggie.
Posted 13 Years Ago
YRAG32 (12/19/2012)
cheers oggie.
On the Ford dual quad intake, 1, 3, 5, & 7 are the cylinders being supplied by the primary side of the forward facing carbs so I’m thinking this is a carb problem rather than an intake problem.  And because it’s primary side related, then the metering rods not being pulled down into the primary jets comes to mind.  The rods could be either stuck in the up position or there is inadequate vacuum to overcome the existing power valve springs to pull the rods down into the jets.  Checking the manifold vacuum with a gauge may help in the troubleshooting.  If the manifold vacuum is low, then using lighter tension power valve springs may be the ticket.  Beyond this, it may be as simple as the primary jetting needing adjusting.
A bit more information on the carbs might help.  Are they new or used?  If used, have the jets and/or metering rods been changed out previously?
