Visits: 39.5K
Keith in the Rolling Bones car is up to 187.564 and got his 175 wings. Still running at this time. Timmy McMasters just took the title of worlds fastest Y-block with a 192.365 but hit a piece of pipe, possibly someone's exhaust tube, slowing to about 180. Blew a rear tire and damaged the suspension so he is on the way home with a BIG smile. Haven't heard anything about Charlie Burns as yet.
57FordPU
Visits: 73.6K
My goal was always to be at the USFRA September meet, but that was cancelled. The SCTA October meet is now the hopeful time to go. Congratulations to Keith and Tim for some great runs. You make the Y-Block and MEL fans very proud.
BurnsRacing981@gmail.com
57FordPU
Visits: 73.6K
A bit of bad news. The cam went flat in last minute warmups. The cam broke in just fine during the initial 25 minute run-in and again for the first few warm ups to tune. After a few more warmups and valve adjustments, I discovered that two of the lobes had started to go flat. I'm not getting any younger, but I will be ready for next season.
Cliff
Visits: 13.9K
Hi Charlie, what lifters were you using? also what was the seat pressure.
Thanks Cliff
ian57tbird
Visits: 21.7K
Sorry to hear that Charlie.
57FordPU
Visits: 73.6K
Hi, Cliff. The lifters are Johnson Hy-Lift. I'm not able to find my notes on the spring seat pressure, I'll look for it. The engine was actually built 7 years ago.
Cliff
Visits: 13.9K
Got it, I'm running Trend Tool Steel Lifters and a Comp nitrated cam, I hope that it stays good.
Posts: 3.3K,
Visits: 238.8K
Charlie:..I don't know, but maybe because the engine sat for several years assembled, might be the key to the Cam or lifter failure?..
57FordPU
Visits: 73.6K
I wouldn't doubt it Paul. If that's the case, it's all my fault for not running it in early and at least turning it over by hand periodically. All the same kind of parts have performed very well for me throughout all these years. It's nothing that Tim McMaster cannot fix and hopefully I will be able to get it to him soon so that I can run it in again.
Visits: 206.1K
Charlie. Can you give some more detail on which lobes went flat on the camshaft? There are a multitude of reasons for a camshaft to go flat but sitting for a number of years is getting close to the top of the list. While I don’t see lifter shank diameters being a problem with the HyLift Johnson lifters, it is a problem with other brands. While they may fit in the bores, they are not in a position to turn freely if on the large side of spec. It’s extremely important that the lifters have at least 0.001” clearance in the lifter bores as any tighter than this inhibits their ability to turn freely in the bores. Here’s a list of items that contributor to camshaft and/or lifter failures. https://www.eatonbalancing.com/2012/11/06/camshaft-and-lifter-failure-causes-2/
