57+ or Remanufactured Dizzy
Posted By lazylnm 2 Weeks Ago
lazylnm
Posted 2 Weeks Ago
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 56, Visits: 699
The car is a ’55 Crown with a 272ci, an E-4 cam; otherwise stock.  3sp O/D, 6v.  I currently have the stock 2bbl and Load-O-Matic.  My ultimate plan is to install my Edelbrock 553 based tri-power that I’ve had for 45+ years, knowing that the LOM has to be replaced.  And knowing a modern 4bbl or EFI would be an easier install and outperform the vintage tri-power.  The goal of the car is to have a reliable cruiser that sounds good.  Not looking for ultimate speed or HP.
I’m wondering what advantages, aside from the very obvious, there are to rebuilding a ‘57+ unit vs using a remanufactured dizzy that utilizes a more modern core.  Do the newer cores offer a revised design that is seen as superior?  Availability of parts?
Some time ago, I purchased an Autolite remanufactured unit that was advertised as using an original case – they just didn’t specify from what.  The unit I got is a D8TF which I believe is from a 1978 truck.  The good news is that the dimension from the bottom of the gear to the end of the shaft is .995” and shaft diameter is slightly undersize at .4625”.   Before I proceed much further, I’d check all the dimensions against the original and do the “see if it even fits” test. The issue is that there is no extended collar at the top to ride on the block when installed.  Instead, there is a stepped down, beveled shoulder.  http://forums.y-blocksforever.com/uploads/images/88420b99-fbd7-4b38-93c4-93c.jpegThe bottom edge measures 4.997” – slightly more than the target 4.991-4.996” – from the bottom of the gear.  I’m thinking I could have my local machine shop turn the shoulder square, permanently install a split collar and then machine the bottom surface to 4.991-6”.  The OD may need to be turned down to fit the recess in the block.  I’d then reinstall the guts including different springs and bushings to change the curve while also changing out the points and condenser.
Or should I find a rebuildable ‘57+ unit?
What are your thoughts, experience or advice?
Mike
Posted 2 Weeks Ago
Last Active: 25 minutes ago
Posts: 2.0K, Visits: 306.7K
The DIST you show is a 1978 SBF (D8TF - it should be a DS II converted to points)
1957/59 FYB cores are becoming scarce and that is the reason rebuilders substituted a modified SBF.
Were you able to install and run the DIST OK initially?
lazylnm
Posted 2 Weeks Ago
I've never installed the remanufactured unit.  Without the extended flange, I was concerned that it would bottom out on either the gear or the oil drive rod - neither of which sounds good.  That, along with no flange for the hold clamp to capture, I didn't see how it would work without modifications.  Hence the split ring idea.
You mention '57-59 cores specifically.  Can I assume the ball bearing breaker plate more desirable than hinged units?
Mike
lazylnm
Posted 2 Weeks Ago
Who rebuilds FYB distributors?  Assuming it needs everything from bearings on up?
Mike
Posted 2 Weeks Ago
Let me ask you a question that I should have asked at the beginning ...
You are now using a 1955 6V DIST that is LOAD-O-MATIC?
If you go to 1957/ DIST, it will be a DUAL ADVANCE which will require a PORTED VACUUM SOURCE rather than the LOM controlled signal through a CARB SPARK CONTROL valve.
http://forums.y-blocksforever.com/uploads/images/c7d872ef-15eb-4f42-afab-b233.jpg
http://forums.y-blocksforever.com/uploads/images/80c60501-43b6-42b3-b7a0-38e0.png
http://forums.y-blocksforever.com/uploads/images/91f665cd-f6ea-4bdf-a27b-abb9.png
Does your center carb (what model - FORD - HOLLEY - STROMBERG, etc.?.) have a SPARK CONTROL VALVE?
The DIST you have now will work (if machined and assembled correctly) if you can provide a ported vacuum source.
The car is going to remain 6V?
Let is know.
lazylnm
Posted 2 Weeks Ago
Right now, I have the 6v LOM distributor and matching 2 bbl.  Vacuum signal comes off the port in the carb body.  I intend to keep the 6v, pos GND.
When I change over to the tri-power, I plan to first change out the distributor, test it, then install the new intake system.  The manifold is an Edelbrock 553; carbs are Ford script 94's.  I plan to rework the carbs with new spark control valve & remove them from the secondaries, rejet them, accelerator pumps, block of vacuum ports, etc.
You state that the Reman distributor will work once the fitment issues are resolved.  Any concern over adding the split collar fix?  Before I start down that path, I would test fit it into the block and check all the dimensions against the original LOM.
OR, I could find a '57+ distributor and get it rebuilt for probably the same cost as the machining.  Any advantages for one over the other?
Mike
Posted 2 Weeks Ago
The manifold is an Edelbrock 553; carbs are Ford script 94's.  I plan to rework the carbs with new spark control valve & remove them from the secondaries, rejet them, accelerator pumps, block of vacuum ports, etc."
So all the three H94's have a SPARK CTL VLV and you are going to disable the valves on the end carbs?
The DUAL ADV DIST requires a PORTED VACUUM SIGNAL to work correctly. The LOM signal is too weak,
You will have to modify one of the carbs to provide the correct signal. There is a TECH ARTICLE available describing the modification.
How well does the engine run off the present LOM or are you wanting more and quicker acceleration?
I would use the DIST you have now and depending on how the rebuilder modified it (shaft length and gear placement) and the quality of parts used will save you some money. You just have to verify the conversion was done correctly.
The DIST is a DURASPARK II design which has a better internal design to make advance adjustments easier and finding NOS parts will be much easier.
The points and condenser are 12V POS but can operate off a 6V SYSTEM by reversing the GRD on it.
EDIT - w/6V COIL (04 NOV 2026)
HERE Is An Earlier Thread Regarding SBF DIST Conversions -
http://forums.y-blocksforever.com/Topic133762-1.aspx
Posted 2 Weeks Ago
Posts: 3.7K, Visits: 498.3K
Here are two people that rebuild the YBlock distributors in case you decide to go with one:
Lou Sumas  440-439-5628
Lee Johnson  812-598-8965
I have done business with Lou for my spares.  Seems to be good.  One he did I sold to another person and got no complaints about it.  Both were the 57-early 59 style.  Supposedly, the late 59 and later ones are the better of the two designs.
There seems to be a good amount of replacement parts available for the 57-early 59 style based in the info I have from CASCO.  I don't know about this on the late 59 and up style.
lazylnm
Posted 2 Weeks Ago
Kultulz - that is exactly what I was trying to find out - If there is an advantage to the newer distributor.  I will pull the LOM and compare dimensions between the original and replacement.  I'll then confirm the SBF does indeed fit.  If that passes, I'll go talk to my machine shop concerning the split ring modifications. When I reinstall everything, I plan to replace the points and condenser with quality I know.
Thanks for the link to the SBF conversions.  It didn't come up in my searches.  It will be great reading.
This is uncharted territory for me as I've never done more than change the consumables of a distributor before.
Thanks for your insight.
Mike
lazylnm
Posted 2 Weeks Ago
Paul - I'll keep your contacts in my back pocket should I wind up rebuilding a '57+.
Thanks for letting me know.
Mike
