By lazylnm - 2 Weeks Ago
The car is a ’55 Crown with a 272ci, an E-4 cam; otherwise stock. 3sp O/D, 6v. I currently have the stock 2bbl and Load-O-Matic. My ultimate plan is to install my Edelbrock 553 based tri-power that I’ve had for 45+ years, knowing that the LOM has to be replaced. And knowing a modern 4bbl or EFI would be an easier install and outperform the vintage tri-power. The goal of the car is to have a reliable cruiser that sounds good. Not looking for ultimate speed or HP. I’m wondering what advantages, aside from the very obvious, there are to rebuilding a ‘57+ unit vs using a remanufactured dizzy that utilizes a more modern core. Do the newer cores offer a revised design that is seen as superior? Availability of parts? Some time ago, I purchased an Autolite remanufactured unit that was advertised as using an original case – they just didn’t specify from what. The unit I got is a D8TF which I believe is from a 1978 truck. The good news is that the dimension from the bottom of the gear to the end of the shaft is .995” and shaft diameter is slightly undersize at .4625”. Before I proceed much further, I’d check all the dimensions against the original and do the “see if it even fits” test. The issue is that there is no extended collar at the top to ride on the block when installed. Instead, there is a stepped down, beveled shoulder. The bottom edge measures 4.997” – slightly more than the target 4.991-4.996” – from the bottom of the gear. I’m thinking I could have my local machine shop turn the shoulder square, permanently install a split collar and then machine the bottom surface to 4.991-6”. The OD may need to be turned down to fit the recess in the block. I’d then reinstall the guts including different springs and bushings to change the curve while also changing out the points and condenser. Or should I find a rebuildable ‘57+ unit? What are your thoughts, experience or advice? Thanks Mike
By KULTULZ - 2 Weeks Ago
The DIST you show is a 1978 SBF (D8TF - it should be a DS II converted to points)
1957/59 FYB cores are becoming scarce and that is the reason rebuilders substituted a modified SBF.
Were you able to install and run the DIST OK initially?
I've never installed the remanufactured unit. Without the extended flange, I was concerned that it would bottom out on either the gear or the oil drive rod - neither of which sounds good. That, along with no flange for the hold clamp to capture, I didn't see how it would work without modifications. Hence the split ring idea. You mention '57-59 cores specifically. Can I assume the ball bearing breaker plate more desirable than hinged units? Mike
Who rebuilds FYB distributors? Assuming it needs everything from bearings on up? Mike
Let me ask you a question that I should have asked at the beginning ...
You are now using a 1955 6V DIST that is LOAD-O-MATIC?
If you go to 1957/ DIST, it will be a DUAL ADVANCE which will require a PORTED VACUUM SOURCE rather than the LOM controlled signal through a CARB SPARK CONTROL valve.
Does your center carb (what model - FORD - HOLLEY - STROMBERG, etc.?.) have a SPARK CONTROL VALVE?
The DIST you have now will work (if machined and assembled correctly) if you can provide a ported vacuum source.
The car is going to remain 6V?
Let is know.
Right now, I have the 6v LOM distributor and matching 2 bbl. Vacuum signal comes off the port in the carb body. I intend to keep the 6v, pos GND. When I change over to the tri-power, I plan to first change out the distributor, test it, then install the new intake system. The manifold is an Edelbrock 553; carbs are Ford script 94's. I plan to rework the carbs with new spark control valve & remove them from the secondaries, rejet them, accelerator pumps, block of vacuum ports, etc. You state that the Reman distributor will work once the fitment issues are resolved. Any concern over adding the split collar fix? Before I start down that path, I would test fit it into the block and check all the dimensions against the original LOM. OR, I could find a '57+ distributor and get it rebuilt for probably the same cost as the machining. Any advantages for one over the other? Mike
" The manifold is an Edelbrock 553; carbs are Ford script 94's. I plan to rework the carbs with new spark control valve & remove them from the secondaries, rejet them, accelerator pumps, block of vacuum ports, etc."
So all the three H94's have a SPARK CTL VLV and you are going to disable the valves on the end carbs?
The DUAL ADV DIST requires a PORTED VACUUM SIGNAL to work correctly. The LOM signal is too weak,
You will have to modify one of the carbs to provide the correct signal. There is a TECH ARTICLE available describing the modification.
How well does the engine run off the present LOM or are you wanting more and quicker acceleration?
I would use the DIST you have now and depending on how the rebuilder modified it (shaft length and gear placement) and the quality of parts used will save you some money. You just have to verify the conversion was done correctly.
The DIST is a DURASPARK II design which has a better internal design to make advance adjustments easier and finding NOS parts will be much easier.
The points and condenser are 12V POS but can operate off a 6V SYSTEM by reversing the GRD on it.
EDIT - w/6V COIL (04 NOV 2026)
By paul2748 - 2 Weeks Ago
Here are two people that rebuild the YBlock distributors in case you decide to go with one: Lou Sumas 440-439-5628 Lee Johnson 812-598-8965 I have done business with Lou for my spares. Seems to be good. One he did I sold to another person and got no complaints about it. Both were the 57-early 59 style. Supposedly, the late 59 and later ones are the better of the two designs. There seems to be a good amount of replacement parts available for the 57-early 59 style based in the info I have from CASCO. I don't know about this on the late 59 and up style.
Kultulz - that is exactly what I was trying to find out - If there is an advantage to the newer distributor. I will pull the LOM and compare dimensions between the original and replacement. I'll then confirm the SBF does indeed fit. If that passes, I'll go talk to my machine shop concerning the split ring modifications. When I reinstall everything, I plan to replace the points and condenser with quality I know. Thanks for the link to the SBF conversions. It didn't come up in my searches. It will be great reading. This is uncharted territory for me as I've never done more than change the consumables of a distributor before. Thanks for your insight. Mike
Paul - I'll keep your contacts in my back pocket should I wind up rebuilding a '57+. Thanks for letting me know. Mike
By Ted - 2 Weeks Ago
The Ford Y-Block (2329/256/272/292/312), the Lincoln Y-Block (317/341/368), and the 289/302 SBF engines share the same basic dimensions on the distributor housing. The distributor gears are different on each though, but they all share the same pilot dimensions and all use the same ¼” hex oil drive shaft. The Ford Y and LYB do have longer shafts with them being almost 5” from the block mount to the bottom of the distributor gear whereas the SBF engines are approximately 4” from the block mount to the distributor gear bottom. Using a SBF distributor requires lengthening of the shaft and using the Ford Y distributor gear.
Ted - The remanufactured unit I have measures .995" from the bottom of the gear to the end of shaft. Bottom of gear to the recessed collar I propose to add a split ring to is 4.997". My next step is to pull my original LOM and do a side-by-side comparison, including gear dimensions and teeth. After that, I'll drop it in to see how it fits into the block and cam drive gear. McMaster has a variety of materials for the split rings - Stainless, carbon steel, plated steel, aluminum. I am thinking aluminum. Once the split ring is installed, drill and insert two roll pins per side into the case. Turn the split ring down as necessary. Comments? Thanks Mike
By oldcarmark - 2 Weeks Ago
Pull your Distributor and check the Dimensions against the rebuilt You bought. The important Measurement is from the Shoulder that sits on top of Block to end of Shaft where it engages Oil Pump Shaft and location of gear. The new one u have would not need the Rubber Seal. Not used on Y-Block. IF the Measurements are correct when compared to Original You can grind down the lower part of shoulder below the Seal on a Bench Grinder so it will drop into Block. I think You may find the rebuilt has a shorter shaft as Ted mentioned. Rock Auto has been or were selling SBF Distributors as Y-Block replacements because of a lack of proper Cores. The Drive Gear does not fully engage the Cam Drive Gear. Not a good choice. If the New one is not correct return it. I have done this Swap at least 3 Times. Important that U get correct Parts. Check Ebay listing 227601867572. Worth looking at as a proper alternative. As a follow up I checked Rock Auto for 1959 Ford with 292. they are listing a Distributor available but from a different Supplier than they used to. If its right or too short U would have to order one and check. The Picture they used is wrong for Y-Block.
By KULTULZ - Last Week
"The issue is that there is no extended collar at the top to ride on the block when installed. Instead, there is a stepped down, beveled shoulder ..."
Wait a minute ... You're saying there is no stop on the housing to position the DIST install depth correctly?
By lazylnm - Last Week
I've been using the bottom of the gear as my reference point. I measured the bottom of the gear to end of shaft at .995"; bottom of gear to break point between the collar that slides into the block and the beveled, reduced diameter shaft at 4.997". I believe both are within spec. Next task is to pull the LOM and compare everything side by side and try to install the reman to see if it engages the cam gear and then turn it over by hand to make sure there aren't any binding issues. That done and passed, it's off to the machinist.
Kultulz - exactly. Hence adding the split collar and a bit of machine work. Your image with the dimensions confirms my understanding of the specs for the bottom of gear to end of shaft and the btm of gear to the mating surface of the extended collar - which I'm going to add. I'm within those specs. Hoping to pull the LOM out today. Thanks for your input Mike
I'm sorry about that as I did not fully understand what you were referring to.
I need to sit up straighter as they are beginning to shoot over my head.
I wonder why it was cut down (if it was)? I have a photo of a period DS DIST and it is not cut down,
Let us know/
That's an interesting notion that they cut the collar down. The case is media blasted - or something - so any machining is not apparent. Just compared the original LOM to the reman. Looked good until I got to the number of teeth of the drive gear - 15 (reman) vs 14 (LOM). HUM Tried the "Does it even fit" test. Turns out the lower collars are almost .250" larger diameter than the LOM. It doesn't even fit in the block. End of story. I'll have the conversation with the vender I bought it from, but I think I'm just SOL. To that end, I just purchased a nice rebuildable core that I had been looking at. I'll research the people an earlier post referred as good rebuilders. To whoever sent those names - thank you. Thanks to everyone who contributed to my journey down this rabbit hole. BTW - the remanufacturer is Autolite out of Winnipeg, model D-404. I have one for sale - cheap Mike
By oldcarmark - Last Week
Autoline D404 listed by Rock Auto. I just emailed them to ask for clarification on what they are selling. Also list D403 for 64 Ford F100. 292. I will let U know what response I get.
By FORD DEARBORN - 2 Weeks Ago
KULTULZ that is an excellent picture with with correct dimensions. I just wanted to mention there is also one more dimension that goes along with this. That is, the .022 - .030" per 57 WSM of shaft end play to allow for variances in the depth of the distributor hole in some engine block. Moot point at this time but the 15 tooth gear would be for a Lincoln Y-block and is supposedly same for the FE engine. lazylnm, are you wanting a dual advance distributor or a LOM?
Dual advance. I have a 272 with an E-4 cam and eventually I want to install a tri-power I've had for 35+ years. Another question - I've always assumed that ALL Y-blocks have the same size opening for the distributor. Early 272's aren't different, are they? LOM collars that insert are 1.4965" vs 1.7395" for the reman. I didn't measure the block. Still wondering how/why my reman is almost 1/4" larger diameter than the LOM I pulled this afternoon. It wasn't even close to fitting. As I mentioned earlier, I just purchased a nice FEK core. But still curious about the reman issue. Mike
All FYB have the same dia. hole (as far as I know - someone will correct me if not).
I think what is going on here is similar to the earlier CARDONE FYB REMANS FIASCO where they were using SBF cores and not making alternations/assembling correctly.
Your REMAN is not machined correctly. But I would not can it until you see what internals were used.
If you can post the new DIST ID ASSY NO, I can tell you the original application.
You know, you might want to mic the opening as the DIST was prone to corrode badly to the opening (alum and iron).
It may need to be honed out (brake cyl hone) slightly for a better fit and provide a good ground.
I overlooked this question also ...
"You mention '57-59 cores specifically. Can I assume the ball bearing breaker plate more desirable than hinged units?"
Yes as there was less dwell variance. FORD replaced the SINGLE PLATE during the 1959 model run with dual breaker plates, mainly for cost I would imagine.
The main problem there is the replacement single breaker plate is becoming harder to find.
By FORD DEARBORN - Last Week
Your measurement of 1.4965" of the casting area that pilots into the block is correct for all Y-block distributors. I don't know what the application is for the reman. distributor you have, maybe someone will recognize it but for sure, it isn't a Y-bock unit. KT may be able to find information from any numbers that may still be on the casting? Since you now have a nice FEK core, inspect the moving parts in the bowl and let us know. I believe FEK is a 57 unit with ball bearing plate? - good luck.
Maybe this will take care of the unsolved mystery: It's from a epay listing the seller indicates will fit various FE Ford engines. Looks like the reman. unit you have??
This is getting interesting ...
FORD ended the FE install in LT in the 1976 model year.
What is needed is the complete DIST ID NO and a complete photo of the D8TF housing.
I have an old 1958 383 MEL DIST (if I can find it) that may shed some light,
The reman unit numbers are D8TF - which I believe is a '76 truck SBF application. Kultulz - The opening in the block is clean - the entire engine was just gone through with only the initial startup procedures on it. The difference between block opening and dist collar was just under 1/4". The FYB distributor I just purchased is an FEK - '57-59. I don't have it yet, but I went for a complete unit that turns. Reaching out to rebuilders. Ford Dearborn - thanks for verifying all FYBs shared the same distributor opening diameter. I just got a message back from the vender claiming the earlier blocks - 272 & smaller - had a smaller diameter distributer opening. I can now call BS. The image you posted looks a lot like what I have - the gear may be closer to the casting in your pic. The three shaft dimensions I originally measured - end of shaft below the gear, btm of gear to retaining collar & shaft diameter were all withing spec for the LOM. I found the reman gear was 1.4135" dia with 15 teeth vs 1.3695" and 14 for the FYB. So even if it did insert, the gears wouldn't mess up. I don't know what the reman was intended for, but it sure wasn't a Y-Block. Mike
Paul - Thanks for the contacts. I pulled a Yahoo search for rebuilders and got two names - Lou & Lee. Came here to add your names - done. I'll contact both now that I have an FEK coming my way. Mike
By paul2748 - Last Week
If I remember correctly, Ted has said that the late 59 to 64 distributors were the better unit.
The "D8" " indicates that it is a 1978 era distributor. B = 50's C = 60's D = 70's
The DIST has to be an FE. A REBUIDLER will usually remove the DIST ID NO on a REMAN. If you notice the ID NO. is missing the PN SUFFIX (D8TF-12127-X) so it has been modified. There was no FE during the 1978 MODEL RUN. The DIST should also be EMBOSSED MOTORCRAFT instead of AUTOLITE. Somewhere on the DIST HSG there should be another RAISED CAST id NO. XXXX-12133-X
If you will when receiving the FYB DIST, lay them side by side and take a photo.
FEK distributors were used in 1957 on 312's, but not all all 312's
