57+ or Remanufactured Dizzy
Posted By lazylnm 2 Weeks Ago
Posted 2 Weeks Ago
Posts: 7.6K, Visits: 206.1K
The Ford Y-Block (2329/256/272/292/312), the Lincoln Y-Block (317/341/368), and the 289/302 SBF engines share the same basic dimensions on the distributor housing.  The distributor gears are different on each though, but they all share the same pilot dimensions and all use the same ¼” hex oil drive shaft.  The Ford Y and LYB do have longer shafts with them being almost 5” from the block mount to the bottom of the distributor gear whereas the SBF engines are approximately 4” from the block mount to the distributor gear bottom.  Using a SBF distributor requires lengthening of the shaft and using the Ford Y distributor gear.
lazylnm
Posted 2 Weeks Ago
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 56, Visits: 699
Ted - The remanufactured unit I have measures .995" from the bottom of the gear to the end of shaft.  Bottom of gear to the recessed collar I propose to add a split ring to is 4.997".  My next step is to pull my original LOM and do a side-by-side comparison, including gear dimensions and teeth. After that, I'll drop it in to see how it fits into the block and cam drive gear.  McMaster has a variety of materials for the split rings - Stainless, carbon steel, plated steel, aluminum.  I am thinking aluminum.  Once the split ring is installed, drill and insert two roll pins per side into the case.  Turn the split ring down as necessary.  Comments?
Mike
Posted 2 Weeks Ago
Posts: 3.8K, Visits: 33.4K
Pull  your Distributor and check the Dimensions against the rebuilt You bought. The important Measurement is from the Shoulder that sits on top of Block to end of Shaft where it engages Oil Pump Shaft and location of gear. The new one u have would not need the Rubber Seal. Not used on Y-Block. IF the Measurements are correct when compared to Original You can grind down the lower part of shoulder below the Seal on a Bench Grinder so it will drop into Block. I think You may find the rebuilt has a shorter shaft as Ted mentioned. Rock Auto has been or were selling SBF Distributors as Y-Block replacements because of a lack of proper Cores. The Drive Gear does not fully engage the Cam Drive Gear. Not a good choice. If the New one is not correct return it. I have done this Swap at least 3 Times. Important that U get correct Parts. Check Ebay listing  227601867572. Worth looking at as a proper alternative. As a follow up I checked Rock Auto for 1959 Ford with 292. they are listing a Distributor available but from a different Supplier than they used to. If its right or too short U would have to order one and check. The Picture they used is wrong for Y-Block.
Posted Last Week
Last Active: 39 minutes ago
Posts: 2.0K, Visits: 306.7K
"The issue is that there is no extended collar at the top to ride on the block when installed.  Instead, there is a stepped down, beveled shoulder ..."
.  http://forums.y-blocksforever.com/uploads/images/88420b99-fbd7-4b38-93c4-93c.jpeg
Wait a minute ...
You're saying there is no stop on the housing to position the DIST install depth correctly?
http://forums.y-blocksforever.com/uploads/images/e7531c10-0aaf-4dcf-916b-d997.jpg
lazylnm
Posted Last Week
I've been using the bottom of the gear as my reference point. I measured the bottom of the gear to end of shaft at .995"; bottom of gear to break point between the collar that slides into the block and the beveled, reduced diameter shaft at 4.997".  I believe both are within spec.  Next task is to pull the LOM and compare everything side by side and try to install the reman to see if it engages the cam gear and then turn it over by hand to make sure there aren't any binding issues.  That done and passed, it's off to the machinist.
lazylnm
Posted Last Week
Kultulz - exactly.  Hence adding the split collar and a bit of machine work.  Your image with the dimensions confirms my understanding of the specs for the bottom of gear to end of shaft and the btm of gear to the mating surface of the extended collar - which I'm going to add.  I'm within those specs.  Hoping to pull the LOM out today.
Thanks for your input
Mike
Posted Last Week
I'm sorry about that as I did not fully understand what you were referring to.
I need to sit up straighter as they are beginning to shoot over my head.
I wonder why it was cut down (if it was)? I have a photo of a period DS DIST and it is not cut down,
Let us know/
lazylnm
Posted Last Week
That's an interesting notion that they cut the collar down.  The case is media blasted - or something - so any machining is not apparent.
Just compared the original LOM to the reman.  Looked good until I got to the number of teeth of the drive gear - 15 (reman) vs 14 (LOM).  HUM
Tried the "Does it even fit" test.  Turns out the lower collars are almost .250" larger diameter than the LOM.  It doesn't even fit in the block.  End of story.  I'll have the conversation with the vender I bought it from, but I think I'm just SOL.
To that end, I just purchased a nice rebuildable core that I had been looking at.  I'll research the people an earlier post referred as good rebuilders.  To whoever sent those names - thank you.
Thanks to everyone who contributed to my journey down this rabbit hole.
BTW - the remanufacturer is Autolite out of Winnipeg, model D-404.
I have one for sale - cheap
Mike
Posted Last Week
Autoline D404 listed by Rock Auto. I just emailed them to ask for clarification on what they are selling. Also list D403 for 64 Ford F100. 292. I will let U know what response I get.
FORD DEARBORN
Posted 2 Weeks Ago
Posts: 852, Visits: 113.5K
KULTULZ  that is an excellent picture with with correct dimensions. I just wanted to mention there is also one more dimension that goes along with this. That is, the .022 - .030" per 57 WSM of shaft end play to allow for variances in the depth of the distributor hole in some engine block. Moot point at this time but the 15 tooth gear would be for a Lincoln Y-block and is supposedly same for the FE engine.                               lazylnm, are you wanting a dual advance distributor or a LOM?
