57+ or Remanufactured Dizzy
Posted By lazylnm 2 Weeks Ago
Posted Last Week
Posts: 3.7K, Visits: 498.3K
The "D8" " indicates that it is a 1978 era distributor.
B = 50's
C = 60's
D = 70's
Posted Last Week
Last Active: 39 minutes ago
Posts: 2.0K, Visits: 306.7K
The DIST has to be an FE.
A REBUIDLER will usually remove the DIST ID NO on a REMAN. If you notice the ID NO. is missing the PN SUFFIX (D8TF-12127-X) so it has been modified.
http://forums.y-blocksforever.com/uploads/images/fb4873e1-e03d-4be9-80b9-b45e.jpg
http://forums.y-blocksforever.com/uploads/images/50c7dbfa-bd6a-4156-abbb-3acb.png
There was no FE during the 1978 MODEL RUN. The DIST should also be EMBOSSED MOTORCRAFT instead of AUTOLITE.
Somewhere on the DIST HSG  there should be another RAISED CAST id NO. XXXX-12133-X
If you will when receiving the FYB DIST, lay them side by side and take a photo.
Posted Last Week
FEK distributors were used in 1957 on 312's, but not all all 312's
