57+ or Remanufactured Dizzy
Posted By lazylnm 2 Weeks Ago
lazylnm
Posted Last Week
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 56, Visits: 699
Dual advance.  I have a 272 with an E-4 cam and eventually I want to install a tri-power I've had for 35+ years.
Another question - I've always assumed that ALL Y-blocks have the same size opening for the distributor.  Early 272's aren't different, are they?  LOM collars that insert are 1.4965" vs 1.7395" for the reman.  I didn't measure the block.  Still wondering how/why my reman is almost 1/4" larger diameter than the LOM I pulled this afternoon.  It wasn't even close to fitting.
As I mentioned earlier, I just purchased a nice FEK core.  But still curious about the reman issue.
Mike
Posted Last Week
Last Active: 39 minutes ago
Posts: 2.0K, Visits: 306.7K
All FYB have the same dia. hole (as far as I know - someone will correct me if not).
I think what is going on here is similar to the earlier CARDONE FYB REMANS FIASCO where they were using SBF cores and not making alternations/assembling correctly.
Your REMAN is not machined correctly. But I would not can it until you see what internals were used.
If you can post the new DIST ID ASSY NO, I can tell you the original application.
Posted Last Week
You know, you might want to mic the opening as the DIST was prone to corrode badly to the opening (alum and iron).
It may need to be honed out (brake cyl hone) slightly for a better fit and provide a good ground.
Posted Last Week
I overlooked this question also ...
"You mention '57-59 cores specifically.  Can I assume the ball bearing breaker plate more desirable than hinged units?"
Yes as there was less dwell variance. FORD replaced the SINGLE PLATE during the 1959 model run with dual breaker plates, mainly for cost I would imagine.
The main problem there is the replacement single breaker plate is becoming harder to find.
FORD DEARBORN
Posted Last Week
Posts: 852, Visits: 113.5K
Your measurement of 1.4965" of the casting area that pilots into the block is correct for all Y-block distributors. I don't know what the application is for the reman. distributor you have, maybe someone will recognize it but for sure, it isn't a Y-bock unit.  KT may be able to find information from any numbers that may still be on the casting?  Since you now have a nice FEK core, inspect the moving parts in the bowl and let us know. I believe FEK is a 57 unit with ball bearing plate? - good luck.
FORD DEARBORN
Posted Last Week
Maybe this will take care of the unsolved mystery: It's from a epay listing the seller indicates will fit various FE Ford engines.  Looks like the reman. unit you have?? http://forums.y-blocksforever.com/uploads/images/64140550-6312-4082-99bb-d95.jpeg
Posted Last Week
This is getting interesting ...
FORD ended the FE install in LT in the 1976 model year.
What is needed is the complete DIST ID NO and a complete photo of the D8TF housing.
I have an old 1958 383 MEL DIST (if I can find it) that may shed some light,
lazylnm
Posted Last Week
The reman unit numbers are D8TF - which I believe is a '76 truck SBF application.  http://forums.y-blocksforever.com/uploads/images/f04cd839-9f47-44b4-a506-6b0.jpeg
 Kultulz - The opening in the block is clean - the entire engine was just gone through with only the initial startup procedures on it.  The difference between block opening and dist collar was just under 1/4".
 The FYB distributor I just purchased is an FEK - '57-59.  I don't have it yet, but I went for a complete unit that turns.  Reaching out to rebuilders.
Ford Dearborn - thanks for verifying all FYBs shared the same distributor opening diameter.  I just got a message back from the vender claiming the earlier blocks - 272 & smaller - had a smaller diameter distributer opening.  I can now call BS.  The image you posted looks a lot like what I have - the gear may be closer to the casting in your pic.  The three shaft dimensions I originally measured - end of shaft below the gear, btm of gear to retaining collar & shaft diameter were all withing spec for the LOM.  I found the reman gear was 1.4135" dia with 15 teeth vs 1.3695" and 14 for the FYB.  So even if it did insert, the gears wouldn't mess up.  I don't know what the reman was intended for, but it sure wasn't a Y-Block.
Mike
lazylnm
Posted Last Week
Paul - Thanks for the contacts.  I pulled a Yahoo search for rebuilders and got two names - Lou & Lee.  Came here to add your names - done.  I'll contact both now that I have an FEK coming my way.
Mike
Posted Last Week
Posts: 3.7K, Visits: 498.3K
If I remember correctly, Ted has said that the late 59 to 64 distributors were the better unit.
