Visits: 6.3K
Maybe the condenser was to avoid radio interference???
Last Active: 16 minutes ago
Posts: 2.0K,
Visits: 306.7K
alanfreeman (10/14/2024)
Maybe the condenser was to avoid radio interference??? Correct, but it will usually be in either the ignition and/or charging system.
Visits: 113.5K
That particular oil pressure sender has a contact on a bimetal strip with a fine wire wound around it. That design was used through '55 and possibly '56. As oil pressure increased, a diaphragm increased force on the contact which caused an increase in current thus further heating the bimetal strip enough to cause the contact to open/close again. The same current flowed through the bimetal device in the gauge which moved the pointer accordantly. As stated above, condensers were used as noise filters on ignition and charging systems that had operating contacts also. AM radios picked up a lot of electrical noise in those days. I'm not sure at this time, but those noise suppressor caps had a similar value as an ignition cap. I'll see if I can find that information.
Posts: 1.9K,
Visits: 195.0K
Ford Dearborn, if I’m reading that correctly, Lincoln also used the King Seeley gauges?
Visits: 113.5K
IF King Seeley is the contact/heater device in the sender then I would say yes. I know the big change was in 1957 but even the 56 Lincoln car used the contact/heater method in the fuel sender. I would think that when 12 volts came about in 56 the senders were probably calibrated differently. This method was also used in the trucks, at least according to my 54/55 truck WSM so it must have been a Ford instrumentation design across the board until 1957. In '57, a voltage regulator for the instruments was incorporated putting stability into the system and simplifying components. This is just my understanding of the subject so hopefully others may have additional information to add.
Posts: 1.9K,
Visits: 195.0K
This link is to a very old post about the King Seeley’s. Some of the drawings seem to have been lost to time, and there was a more extensive post on adjustments I’ve never been able to track down. Appreciate Ford “bought out” these gauges, and when I was looking for them the most active sites where Jeep/Willy’s for info and rebuilders http://forums.y-blocksforever.com/Topic22135-1.aspx
Visits: 220
I faced the same issue, and wanted to pre oil my new stroker EVERY time it was started (once monthly about) so I bought a pre-oiling system from a company called Masterlube. Basically, its tank, with Schrader valve. Add oil, pressurize (depends on application) mine is at 60lbs. (has guage to check fill and pressure drop. solenoid controlled by toggle switch on dash sends about 40lbs oil pressure to engine before startup. BEST thing I ever bought for this long term project. Permanently attached to radiator support. Its a little bulky/unsightly for some, but my expensive build has never had a dry start.
Posts: 1.4K,
Visits: 2.0K
I would like to see it. Price?
