First start
Posted By B-rad 2 Years Ago
Posted 2 Years Ago
Last Active: 16 minutes ago
Posts: 2.0K, Visits: 306.7K
You have a 1954 LINC - 317CI.
Does it have an oil pressure gauge or lamp?
B-rad
Posted 2 Years Ago
Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)Supercharged (927 reputation)
Posts: 362, Visits: 1.5K
Gauge
Brad
Sierra Vista Arizona
1954 Lincoln Capri
B-rad
Posted 2 Years Ago
I looked at the threads and they just needed a little filing. It went right into the block. Golden. It's gonna be a pain trying to get a wrench on it with the filter and oil pump right there.
Brad
1954 Lincoln Capri
Posted 2 Years Ago
Posts: 1.9K, Visits: 195.0K
If the filing was just to get it started, the threads that seal it are probably fine. Tapered pipe threads, tight, but don’t over do it. Better to tighten it a bit later than Armstrong it and strip something.
I’m glad you’re getting close.
For the rest of the site, my wife and I had the pleasure of having lunch with Brad and his wife, and being invited to see the Lincoln. There’s some work to be done, but it’s all pretty much complete and a heavily optioned car. It’ll be a jewel when it’s done.
B-rad
Posted 2 Years Ago
Thanks Mike, it was nice meeting you two too.
And now I can turn the oil pump and hopefully see oil up in the rockers. Without any more leaks. That'll be a big relief knowing that part of the rebuild was done right. Then in the bay it'll go.
It'll be a long journey from there, paint, interior, all the accessories. Rewiring, converting to 12v, power windows, seats. Changing out the treacle brakes for a two line p brake mc.
Basically the front suspension and 4 wheels brakes rebuilt, tank and fuel line redone, are all I've gotten done besides getting the engine and tranny rebuilt.
The pic is for those that haven't seen it yet.
Brad
1954 Lincoln Capri
Posted 2 Years Ago
B-rad (10/12/2024)
Just like it but mine has a rivet. Does that make a difference?
Herein lies the problem -
The sender you removed, if OEM and not aftermarket, appears as a 1956/ sender which is for a 12V SYSTEM.
The prior 6V sender appeared as -
http://forums.y-blocksforever.com/uploads/images/6d82cc7d-d2bc-48b1-8f60-65e1.jpg
There was available a 2PIN TAB to attach to the 6V sender to convert it for this particular application.
It may have been installed years ago when the supposedly correct sending switch was not available.
As for the condenser, is there any stamped identification on the bottom of the cylinder?
Posted 2 Years Ago
Remove the filter so you can get to it easily.
Most likely, FORD offered a SPECIAL SERVICE TOOL (bent crows-foot) to get at it while in the chassis.
If there was one, it will be shown in the WSM.
B-rad
Posted 2 Years Ago
Brad
1954 Lincoln Capri
B-rad
Posted 2 Years Ago
I think it says
45-85036-1
FDC 108701
Brad
1954 Lincoln Capri
Posted 2 Years Ago
THANX! for posting the nos.
I cannot cross it over. It is an ENGINEERING PN. Need a FORD PN INTERCHANGE MANUAL and I do not have one.
Sill wondering why a suppressor on the circuit.
