PCV baffle configuration
Posted By Kingfisher 2 Years Ago
Kingfisher
Question Posted 2 Years Ago
Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)
Posts: 29, Visits: 816
I sorta hate to add another PCV question! There are plenty of threads and I reckon I've read most of them but can't quite find the answer.
I have an ACE finned valley cover to put on my 312 with a grommet and valve to suit. The cover comes with a PCV provision - a circular flat area ready to be machined out and 2 posts on the underside which presumably could be drilled and tapped to screw on a baffle (not sure I would be comfortable with the possibility of dropping a screw).
What configuration should the baffle be? I imagine something like Mummert's maybe, but I can't see a decent photo of his. Is it sealed on just 2 sides, allowing airflow in through the outer 2 edges? Or is another design better? And what about the large vertical baffle that the stock cover comes with? I gather it's not particularly necessary?
(It's interesting that they put a baffle below the filler though)
Thanks, Mark
http://forums.y-blocksforever.com/uploads/images/9f4cf970-f882-4b11-9d77-c4c3.jpg
Posted 2 Years Ago
Last Active: 4 days ago
See if these help.
FoMoCo 1958-1964 valley cover
http://forums.y-blocksforever.com/uploads/images/93e29927-723f-443f-9de4-4494.jpg
Mummert valley cover with PCV valve
http://forums.y-blocksforever.com/uploads/images/00db62e7-7737-42ad-bcf9-686d.jpg
Mummert valley cover without PCV valve
http://forums.y-blocksforever.com/uploads/images/4f2a4036-65b0-403b-9049-3e11.jpg
Blue Thunder valley cover with PCV valve
http://forums.y-blocksforever.com/uploads/images/3834cf68-bddd-442b-b8a3-b888.jpg
Posted 2 Years Ago
Posts: 1.2K, Visits: 1.8K
Kingfisher, I have the same Ace valley cover. Ace told me that they don't install a baffle due to various lengths of pcv valves. I would think if you Loctite the screws or use high-temp epoxy, whatever baffle you use should be secure. I've also considered removing the sheet metal baffle from my original valley cover and tack-welding it to the Ace valley cover. Let me know what you come up with, including photo, and what pcv valve you're using.
Thanks.
Posted 2 Years Ago
Posts: 4.6K, Visits: 38.3K
You could install the sheet metal cover from a stock cover with screws and then spot weld the screws to the cover so they couldn't work loose.
Kingfisher
Posted 2 Years Ago
Thanks Ted, very helpful. What's the welded nut for on the Mummert baffle?
I don't have an original that I can steal the baffle from, but I can certainly bend something similar. And then a couple of screws and spot welds will work I reckon. Thanks all, I'll post a photo when done.
Posted 2 Years Ago
Posts: 6.1K, Visits: 442.8K
A factory breather pipe or pcv adapter attaches via that nut.  You can see a similar item on the factory cover baffle in Ted's picture - that one is spot welded.
Kingfisher
Posted 2 Years Ago
I bought a PCV on ebay that fitted perfectly. It's almost like ACE designed their product to suit.
https://order.ebay.com.au/ord/show?itemId=403582260806&transactionId=1151754649027&mkpid=0&emsid=e11401.m1842.l5919&mkcid=7&ch=osgood&euid=d1ae85d206cd400084961a67e1356152&bu=43765525669&exe=0&ext=0&osub=-1~1&crd=20230513193326&segname=11401#/
I then bent a piece of stainless roughly similar to the original and secured the bolts with some RTV. It's a bit rough to look at, but should work I guess.
http://forums.y-blocksforever.com/uploads/images/15d08b72-3e82-425c-89aa-50d6.jpg
http://forums.y-blocksforever.com/uploads/images/0f083433-42c8-4b3e-a88a-3618.jpg
http://forums.y-blocksforever.com/uploads/images/d31d54d2-341a-4307-8efd-d087.jpg
Posted 2 Years Ago
That looks like a pcv valve for my '88 Firebird.
Ace probably designed it to work with the stock parts, which so happens to be sized such that a pcv grommet does work.
Posted 2 Years Ago
Kingfisher, do you have a part# for the pcv valve? I hope there is some space between the bottom of the valve and the baffle.
Kingfisher
Posted 2 Years Ago
The pcv sits almost flush with the bottom of the cover so there is about 1/2 inch between pcv and the baffle.
