Posts: 2.0K,
Visits: 306.7K
Nicely done. I understand (and the need for) the CLOSED PCV SYSTEM. I really like how you did the HTR HOSE and AC LINE detail. Blower motor inside the heater box? As for the PCV TUBE, I would (IMO) leave it natural as were the later OEM tubing. Not b!tching, but your detailing is spot on (IMO).
Posts: 2.0K,
Visits: 306.7K
Here is a low buck idea- PCV Valve Elbow - Fabricated From 6758 Road Draft Tube
 It will move the valve away from direct spray at the least.
Last Active: 10 days ago
Visits: 2.6K
Thanks Ted So what if I follow your first option...I can run a screw down into the nutsert that someone installed in my valley cover to plug that hole up and then run the appropriately sized grommet and PCV? I don't need to do anything else to that big square "baffle" as far as blocking off oil from getting in there? It's alright to keep the side open as shown in the second photo here?
The existing square baffle does a great job in keeping oil away from the road draft tube opening in the valley cover. No extra filler or foil is needed. Other than just plugging the original ¼-20 hole that’s in the baffle, all you need is a rubber grommet in the existing hole and the PCV valve and you are good to go.
Visits: 2.6K
Thanks Ted.
