I need some help
Posted By pintoplumber 4 Years Ago
pintoplumber
Posted 4 Years Ago
Posts: 1.0K, Visits: 164.2K
I went racing at Beaver Springs today. I made my 1st pass, and they came to my pit and said I was putting down oil the whole way up the track. I checked my oil and I was down a quart. I drove about 2 hours, 95 miles one way to get there. On the way home I used less than 1/2 a quart. I won’t have time to fix it before the shootout and perhaps not this summer. I don’t mind adding oil while I’m driving. Is there someway of putting some kind of diaper on it while at the track? What kind of material would you use? Thanks for any help or ideas. By the way it would be the rear main seal. Dennis
MattsY
Posted 4 Years Ago
Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)
Posts: 82, Visits: 3.6K
Yes Sir! Google "engine diaper" and you'll find 'em at any of your favorite high performance dealers. They are required by the NHRA for certain classes. I'm not sure how I feel about running with a known leak, but it's not my decision to make.
Posted 4 Years Ago
Last Active: 15 hours ago
Posts: 4.6K, Visits: 38.5K
Any idea where it was leaking from?
pintoplumber
Posted 4 Years Ago
Chuck, it’s the rear main seal. I can’t believe it’s as bad as they say. Less that a half a quart in 95 miles on the way home. I would guess some drops every now and then up the track. If I could only catch them.
2721955meteor
Posted 4 Years Ago
Posts: 927, Visits: 190.0K
have a kit for ys,as what I see as most oil leaks are from the rear of the pan most pans have poor clamping due to old age. my kit is a thicker denser gasket, and a plate that covers the rear 6bolts,pressing on raise dimples on the pan.have sold 3in canada 1 in the us.  75 us plus frt. if interested send me your email and I can send couple of pictures.  ay with no leaks is pos.
Posted 4 Years Ago
Posts: 1.2K, Visits: 1.8K
Meteor, a few months ago, I asked for information in regards to oil-pan-rail reinforcements for Y-blocks. At least one person said that the "bumps" along the rails will not accommodate reinforcements. At least one other person said they aren't necessary. I'm not so sure I agree with them.
I, and possibly others, would like to see a photo of what you have. If it works, you might find some potential customers on the forum.
Thank you.
pintoplumber
Posted 4 Years Ago
They didn’t stop to clean the track after me, I can’t believe it was as bad as they say. There was an accident earlier in the day, some guy in a 4 cylinder probe who was doing 142 mph at the 1/8 mile, went into the grass and brushed the guardrail. Don’t know what he would have been doing at the finish, as he crossed the line in the grass. Dennis
Posted 4 Years Ago
Posts: 3.7K, Visits: 323.2K
Dennis, I wonder if you got blamed for someone else's oil down.  Also, it they didn't clean up the track afterwards there couldn't be much oil on the track.  If you were to install meteor's kit, you would have the pan off, you're only minutes away from replacing the rear seal.  If you don't see a small puddle when you park the truck, I wouldn't worry about it and go ahead and run it at the shootout.
2721955meteor
Posted 4 Years Ago
my email is ct1940@shaw.ca,send me yours and I will forward several pictures. I have not mastered sending pictures to the site(yet)
have the system on my mercy (56yblock 4v) no drips, re the rails they are more secure than the bolt holes which are sunk after years of reticent etc
the plates are water cut and very accurate. thanks for the interest. cliff t
Posted 4 Years Ago
I suspect they saw a spot of oil on the track after you took off. Maybe yours, maybe not. If its the rear seal you could use a tie down strap up and over the transmission to hold an old folded towel in the area between the pan and transmission. See you in June!
