Jack Groat
Posted 6 Years Ago
Visits: 1.4K
I just discovered my new ARP main cap bolts are too long. As it turns out, I must have a block earlier than mid 59. After that, Ford deepened the main cap bolt depth. I was told go to your friendly machine shop and have them deepen the main cap threads. I just got off the phone with them and they said they have never heard of this operation and are reluctant to go forward with the process.
I can certainly use the existing bolts or find new of the same length. I was told the existing bolts are really too short for a high performance engine. The ARP bolts are only available in the longer length. I could try and find another machine shop familiar with the operation.
My engine will have 10:1 compression, a performance cam, and 3-2bbl carbs. I may, if given the opportunity see my quarter mile time or run it on a chassis dyno. Otherwise the engine will not see much severe action.
OK guys. Need your advice and opinions.
Cliff
Visits: 13.8K
It's an easy job to drill and tap the main holes deeper, you can do it with a hand drill if your careful, use the main cap as a guide, it is about a 1 hour job for all bolts, when your done look down the oil galley and make sure the bolts do not block the oil galley.
I Have ground off threads of Grade 8 bolts/studs for my GMC head. I have also used additional hardened washers under the cap screw head. Curious, why didn’t you go with ARP studs? I order them by length from them for my racing GMC’s along with nuts and washers. I never tell them the engine because they have no listing for it so I do it by size. If they give me the part number sometimes I look it up at Summit or Competition Products and the have them at a lower costs. Good luck.
Studs may not be required and they require clearancing of the rear main seal retainer, which I wouldn't recommend unless they are really needed for the build of the engine.
Posts: 1.4K,
Visits: 1.9K
If your machine shop is reluctant to do the work, I wouldn't attempt it. Find a machinist who knows these engines and has done it. Send an email to Ted.
Visits: 498.0K
I would ask Ted if you really need the longer bolts for the engine you have (actually need the additional length for high performance use)
Jack Groat
Visits: 1.4K
If Ted says to do it, I'm gonna do it!!
I talked to my machine shop again and they asked me if the block will set flat upside down on a milling table; It will.. in which case it should be an easy fix. They told me to bring the caps and bolts and they will check the line bore before it leaves the shop.
FYI.. I have read the "Rebuild your Y-block" cover to cover and lots of comments and questions on this website and I never heard of this issue. When I called John Mummert he said it was fully explained in the documentation he sent me. As it turned out, setting right next to the recently opened bag of main cap bolts was a folded sheet explaining the whole situation. Hopefully, by posting this I can save someone else from getting blind sided by the same issue.
Visits: 498.0K
What did John say to do?
Jack Groat
Visits: 1.4K
When you asked, "What did John say?" I assume you meant what was written on the sheet of paper with the bolts.
First he listed the block casting numbers that did or did not need the bolt holes deepened. Then directions on how deep to drill, the drill size and a warning... do not attempt to do this by hand...
Visits: 498.0K
