By Jack Groat - 6 Years Ago
I just discovered my new ARP main cap bolts are too long. As it turns out, I must have a block earlier than mid 59. After that, Ford deepened the main cap bolt depth. I was told go to your friendly machine shop and have them deepen the main cap threads. I just got off the phone with them and they said they have never heard of this operation and are reluctant to go forward with the process.
I can certainly use the existing bolts or find new of the same length. I was told the existing bolts are really too short for a high performance engine. The ARP bolts are only available in the longer length. I could try and find another machine shop familiar with the operation.
My engine will have 10:1 compression, a performance cam, and 3-2bbl carbs. I may, if given the opportunity see my quarter mile time or run it on a chassis dyno. Otherwise the engine will not see much severe action.
OK guys. Need your advice and opinions.
By Cliff - 6 Years Ago
It's an easy job to drill and tap the main holes deeper, you can do it with a hand drill if your careful, use the main cap as a guide, it is about a 1 hour job for all bolts, when your done look down the oil galley and make sure the bolts do not block the oil galley.
I Have ground off threads of Grade 8 bolts/studs for my GMC head. I have also used additional hardened washers under the cap screw head. Curious, why didn’t you go with ARP studs? I order them by length from them for my racing GMC’s along with nuts and washers. I never tell them the engine because they have no listing for it so I do it by size. If they give me the part number sometimes I look it up at Summit or Competition Products and the have them at a lower costs. Good luck.
Studs may not be required and they require clearancing of the rear main seal retainer, which I wouldn't recommend unless they are really needed for the build of the engine.
By 55blacktie - 6 Years Ago
If your machine shop is reluctant to do the work, I wouldn't attempt it. Find a machinist who knows these engines and has done it. Send an email to Ted.
By paul2748 - 6 Years Ago
I would ask Ted if you really need the longer bolts for the engine you have (actually need the additional length for high performance use)
If Ted says to do it, I'm gonna do it!!
I talked to my machine shop again and they asked me if the block will set flat upside down on a milling table; It will.. in which case it should be an easy fix. They told me to bring the caps and bolts and they will check the line bore before it leaves the shop.
FYI.. I have read the "Rebuild your Y-block" cover to cover and lots of comments and questions on this website and I never heard of this issue. When I called John Mummert he said it was fully explained in the documentation he sent me. As it turned out, setting right next to the recently opened bag of main cap bolts was a folded sheet explaining the whole situation. Hopefully, by posting this I can save someone else from getting blind sided by the same issue.
What did John say to do?
When you asked, "What did John say?" I assume you meant what was written on the sheet of paper with the bolts.
First he listed the block casting numbers that did or did not need the bolt holes deepened. Then directions on how deep to drill, the drill size and a warning... do not attempt to do this by hand...
By NoShortcuts - 6 Years Ago
Paul. IF you click the link below you'll view the complete information sheet that John Mummert includes for guiding those installing the longer ARP bolts or studs that are recommended. http://www.ford-y-block.com/ARPmaininstall.htm
Looking back, production of the FoMoCo y-block began in the U.S. for the 1954 model year. For the engineers to decide in Spring of 1959 model year to increase the length of main cap bolts in the 292 and 312 ('59 & '60 Merc application!) engines was significant. Imagine how many 239, 256, 272, 292 and 312 y-block engine blocks had been made between 1954 and mid-1959 for the various Ford car, Ford pick-up truck, Thunderbird, Mercury, Edsel, Ford heavy duty truck, and various industrial and farm related applications. WoW!
A number of y-block engines being re-manufactured by FoMoCo or by Ford Authorized Re-manufacturers had to be found with some pattern of cracking' in the main bearing block webbing area, Extending the length of the main bearing cap bolts was a solution. Seemingly simple enough, but not without expense for FoMoCo to implement. Necessary OR wise to-do for heavy duty applications like big, heavily loaded trucks OR for those actively exercising their engines capability with acceleration, elevated rpms, or load pulling ability.
For those of us putting together anything more than a grocery-getter, if you're going through a pre B9AE engine block with main cap line honing, block squaring, cylinder boring, zero decking for pistons, rotating assembly balancing and the like, installing longer main cap bolts is something GooD to do. Studs are a little more effort to do, but . . . .
By 55blacktie - Last Year
I have a B9AE 292 block that was manufactured in June, 1959. Tomorrow, I will pull one of the main caps and check to see if the threads in the block go all the way to the top, If they do, I will assume that the block was drilled & tapped by Ford to accommodate the longer main-cap bolts.
I would like to install the ARP main-cap studs, and I'm aware of the need to clearance the rear-main-seal retainer, as addressed in John Mummert's video, "Building a Better 312", but there was no mention of having to shorten & notch the stud on the oil-filter side to prevent the blockage of the oil passage. Is this a necessary modification on the B9 and later blocks, or just for the earlier E-series blocks? If so, can it be avoided by using the ARP bolts instead of the studs?
By Ted - Last Year
Ford normally used a grade eight castle head bolt on the rear mains which would allow the rear main seal retainer to clear thus leaving a full surface for the oil pan gasket. Depending upon the year model, the remaining main cap bolts may or may not be grade eight and the use of lock washers on the earlier engines further compounds the height problem. If using studs or non-stock main cap bolts in the rear main cap, then notching the rear seal retainer for bolt clearance is typically necessary. With a smaller head bolt such as ARP, then that notching is minimal. I am not a fan of using studs for either head bolts or main cap bolts for a street performance Ford Y. The torque values are different between studs and bolts and with that in mind, then the proper torque for the fastener should be adhered to when doing both the machine work and the assembly of the engine. For using studs in place of the main bolts, care must be taken that the threaded length that goes into the block does not protrude in the oil galleys at each main bolt hole on the oil filter side of the block. If staying with bolts, then swap out any non-grade eight bolts for grade eight bolts. Using too long a bolt or stud for the FYB main caps is a concern for all the threaded holes on the oil filter side of the block and not just the threaded hole at the oil filter as blocking the oil galley at any of those holes can occur. The other concern is using the later model longer bolts in the early blocks without first checking the threaded depth of the holes. Too long a bolt will simply bottom out prematurely and potentially cause the block to crack or break in that area. Easy enough to check the threaded depth length by first installing the bolts in the holes without the caps and then checking the under-head length of the bolts to the flat on the block where the main caps sit and comparing that number to the actual height of the caps. I do a similar check for the head bolt lengths which can get dicey at times. With the heads and head gaskets in place, the bolts are installed first without the head bolt washers and if the head bolts bottom out against the heads, then those same bolts will be fine with the head bolt washers installed. FYI, I install head bolt washers along with grade eight head bolts on all Y engines. The 1963 and 1964 Ford Y engines came factory equipped with grade eight head bolts which solved some of the head gasket issues when using the earlier grade five and grade six head bolts. Other comments always welcome so do not let this be the last word on the subject. This is just the way I do it.
Thank you, Ted.
One thing that I hadn't considered until after my original post is the possibility of compromising the integrity of a main stud by cutting a v-notch in it to prevent an obstruction of the oil galley. If that's true, doesn't it defeat the purpose of using studs?
By Ted - Last Year
55blacktie (1/26/2025) One thing that I hadn't considered until after my original post is the possibility of compromising the integrity of a main stud by cutting a v-notch in it to prevent an obstruction of the oil galley. If that's true, doesn't it defeat the purpose of using studs? It’s important that the main cap bolt or stud does not protrude so deeply that it blocks the oil passage.
If the rear-main-seal retainer has to be clearanced for ARP studs, does that increase the possibility of oil-pan leakage?
By Ted - Last Year
55blacktie (1/27/2025) If the rear-main-seal retainer has to be clearanced for ARP studs, does that increase the possibility of oil-pan leakage? It does increase the potential for an oil leak. Part of that potential lies in whether the oil pan itself has to be modified to compensate for any main cap fasteners that extend past the gasket sealing surface. An option is to machine the tops of the rear main cap down at the bolt holes just enough to lower the fastener to permit the fasteners to fit either flush with the gasket surface or better yet, sits below the rear seal retainer so that the retainer itself does not have to be modified. Modifying or machining the tops of the fastener heads can also give some more working room in that area. There are several different ways to work around modifying the rear seal area for using different rear main cap fasteners. But unless you are planning on making in excess of 450HP, then the stock grade eight fasteners will prove to be more than adequate. Here's a picture of what I did for a Ford Y. I had a rear cap machined that eliminated the original rear seal retainer and instead had the rear seal combined with the rear main cap similar to what you see on a FE Ford engine (390/428).
Are the ARP Y-block main-cap bolts available in two different lengths? How long are the bolts for the 59-up 292 engines? When I bring my block home from the machine shop, I'll pull a bolt and measure it.
All of the main-cap bolts in my B9AE 292 block are exactly the same. I have to assume they are the original bolts because it's a standard-bore block, and the rod & main journals are also standard. The 1/2-13 bolts have an overall length of 3 inches (excluding the head); the thread length is 1 3/16ths, and the head diameter is 3/4-inch. The block has a separate aluminum real-main-oil-seal retainer that has to be removed before accessing the cap bolts underneath. A 12-point 3/8ths socket is required to remove/replace the retainer bolts. There are no washers.
Although the ARP main-cap-bolt heads are smaller (9/16ths) than the OEM bolt heads (3/4ths), it's still necessary to clearance the rear-seal cap in order for the cap to seat properly; it's close, but no cigar.
By Ted - Last Year
Notching or modifying the rear main seal retainer for non-stock main cap bolts is not a big deal. You do need to be careful in not removing any more material than is absolutely necessary. I typically use a milling machine to do this but careful grinding with a die grinder will accomplish the same thing.
By Ted - Last Year
Here’s another picture of a notched rear main seal retainer. This one has larger notches so it can use machined spacers between the nuts and the main support girdle. The spacers or the main support girdle is not yet installed in this picture.
I used a grinding stone in a drill (my die grinder bit the dust). Even with a drill, there's no problem grinding the aluminum rear-seal cap. I did check the fit numerous times, making sure that I did not remove more material than necessary. The cap is now properly seated, and my work looks as good as any I've seen.
By Joe-JDC - Last Year
I actually installed a plug in the rear main seal housing bolt holes and covered it with silicone and let it set up before installing the oil pan gasket. I also cut the clearance for the rear main cap bolts prior to installation. Made it easier to install the windage tray afterwards.
