Y block trips!
Posted By '49 bomb! 7 Years Ago
'49 bomb!
Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)Supercharged (92 reputation)
Posts: 40, Visits: 1.8K
Got a rebuilt y block, it has "trips".
3 Ford script "94". The center carb.
Has choke, 52 jet's. The 2 out board
No choke 49 jet's. The carbs or just rebuilt by a well-known rebuilder. The issue I'm having is: in order for the car to run I have to have the choke pulled out more than halfway. It has a stock fuel pump with a fuel pressure gauge. I have it set for 3 pounds. But it doesn't seem to hold a steady pressure I had a lot of times it will go all the way down to zero.
So what do you guys think about me having to run with this choke on?
Posts: 3.8K, Visits: 33.3K
What are You using for a Regulator? Try running without Regulator and see what that does. Maybe Carbs are not getting a Constant supply of Gas if the Gauge is reading correctly.?
Last Active: 19 minutes ago
Posts: 2.0K, Visits: 306.6K
You need to first verify pressure and volume supply with a QUALITY MECHANICS fuel pressure tester.
KULTULZ (8/7/2019)
If You have a Vacuum Gauge most also read Pressure. U should be able to "T" into Fuel line between Pump and Car to verify Pressure.
Posts: 3.7K, Visits: 498.2K
If you have to have the choke out, it usually means a vacuum leak.  Check the hoilddown bolts in the intake and carbs as  well as any source that have vacuum or item that is vacuum operated.  Check all vacuum lines.
Could also be a carb float that isn't right.  Even pros make mistakes.  Running progressive linkage?
Cliff
Posts: 904, Visits: 13.9K
3lbs is not enough, I run 4-5
I have a Standard Carter Fuel Pump on mine for an early 60's 352. Maximum Pressure seems to be 4.5-5.5 so really my Pressure Regulator is not doing much except smoothing out Pulses from the Fuel Pump. My Holley Carb is Happy-no Flooding.
'49 bomb!
Thanks for all the replies guys! Yes I am running progressive linkage! haven't been able to check the fuel pressure yet can't find a place to tap-in it's feasible. What I did notice is if I cover the rear outboard carburetor up completely with my hand, it will stall! I had these carburetors reworked by vintage speed to cure this problem. My main concern is why I still have to run with the center choke almost closed?
Posts: 3.7K, Visits: 323.8K
Is that black vacuum hose connected to a PCV?  If so, try plugging it and see if you still have to run with the choke on.  Too big a PCV acts the same as a vacuum leak.
'49 bomb!
That black vacuum hose has two purposes, it does connect to the PCV valve, but it also supplies vacuum for my brake booster.
