Tim Quinn
Visits: 3.5K
Sure would appreciate your help. Do you think $10.00 would pay snail mail ? I'll send you the money for postage and then you can send them to me. Or send 'em to me and I'll send you the $$$$ What ever will work. Tim Quinn 2711 E Vina Del Mar Blvd St Pete Beach, Fl 33706
Last Active: 8 minutes ago
Visits: 37.7K
I probably have a couple of those in the shop. Yours for the postage if you want.
darrell
Visits: 22.1K
these must be pressurized rockers.there has to be bolts in those holes otherwise the shafts would turn as thats what holds them in place.
Visits: 32.4K
If You do need One pretty sure Carl would have a used One. He seems to have just about everything Someone is looking for. Helped Me out when I needed a missing Oil Slinger recently.
Posts: 1.6K,
Visits: 304.7K
 TUBE - B5A 6588-A SUPT - EBU 6575-A Talk to the machinist first and see if he left them out for some reason. If he didn't, GOOGLE the PN's exactly as shown and you should come across them.
darrell
Visits: 22.1K
is there one on the other side.some people block these of.check to see if yours is blocked of which you can see just by looking.if thats the case start the engine and see how much oil is running in the heads.it should not run out with the rocker covers of.
Tim Quinn
Visits: 3.5K
That's it !!!! That tube is missing from the left bank for sure !! Big time thanks. NOW, where do I find these tubes ? Any hints ? Let me know, Tim in Florida AGAIN, BIG TIME THANKS
Posts: 1.6K,
Visits: 304.7K
I noticed that on the head on the left, that there is a tube running to a drain hole at the top of the head. There is not tube like this on the head of my car.
Could this be the problem????
Yes. If left off intentionally/unintentionally or if the rocker arm assembly was pressurized with no relief, the oil supply can pool in the head surface and overwhelm the valve seals. The left heads usually sees more supply.
Tim Quinn
Visits: 3.5K
I noticed that on the head on the left, that there is a tube running to a drain hole at the top of the head. There is not tube like this on the head of my car. Could this be the problem???? Get back, Thanks, Tim in Florida
Tim Quinn
Visits: 3.5K
Do we need to use a inline PCV ?????????
