Frost Plug Size for Road Draft Tube.
Posted By oldcarmark 7 Years Ago
Last Active: 3 Weeks Ago
Does anyone know the Size of Frost Plug used to plug the Block when the Road Draft Tube is removed? I did One Years ago and someone on the Site knew the proper Size, Can't find that Info
darrell
Posts: 455, Visits: 22.2K
1 1/4
Posts: 3.6K, Visits: 497.7K
Do the bolt holes go completely into the inside?  On a side mounted road draft tube, a plate is usually used.  You can make one up yourself using the gasket for sizing and a piece of aluminum
The Bolt Holes go through to the Crankcase. I used a 1 1/4" Plug and added 2 Bolts with Washers that overlap the Plug so it can't come out.
If you are worried that it might come out, aren't you worried that it may go in?
oldcarmark (11/8/2018)
darrell
that plug is not going anywhere.
56_Fairlane
Last Active: 8 Months Ago
Posts: 575, Visits: 14.6K
There is a block off plate specially for this that is available as an OEM part. I have on on my engine.
~DJ~ AKA "Bleach"
Got a part #? Found it. B5S-6869-A. Originally a T-Bird Part to block off opening in Block with rear Draft Tube on Birds.
56_Fairlane
Here's an ebay listing for it: https://www.ebay.com/itm/NOS-FORD-THUNDERBIRD-B5S6869A-1955-1957-55-56-Y-BLOCK-CRANKCASE-BLOCK-OFF-PLATE-/311350594328
It's considerably more than a freeze plug but I would trust it more.
~DJ~ AKA "Bleach"
Larry's sells a Repro for a lot less than the Originals. Ordered a Fuel Pump Block Off Plate from Amazon.Thanks
