| By oldcarmark - 7 Years Ago |
		| Does anyone know the Size of Frost Plug used to plug the Block when the Road Draft Tube is removed? I did One Years ago and someone on the Site knew the proper Size, Can't find that Info |
		| By darrell - 7 Years Ago |
		| 1 1/4 |
		| By paul2748 - 7 Years Ago |
		| Do the bolt holes go completely into the inside?  On a side mounted road draft tube, a plate is usually used.  You can make one up yourself using the gasket for sizing and a piece of aluminum
		| The Bolt Holes go through to the Crankcase. I used a 1 1/4" Plug and added 2 Bolts with Washers that overlap the Plug so it can't come out. |
		| If you are worried that it might come out, aren't you worried that it may go in?
 oldcarmark (11/8/2018)
		| that plug is not going anywhere. |
		| By 56_Fairlane - 7 Years Ago |
		| There is a block off plate specially for this that is available as an OEM part. I have on on my engine.
		| Got a part #? Found it. B5S-6869-A. Originally a T-Bird Part to block off opening in Block with rear Draft Tube on Birds. |
		| Here's an ebay listing for it: https://www.ebay.com/itm/NOS-FORD-THUNDERBIRD-B5S6869A-1955-1957-55-56-Y-BLOCK-CRANKCASE-BLOCK-OFF-PLATE-/311350594328 It's considerably more than a freeze plug but I would trust it more.
		| Larry's sells a Repro for a lot less than the Originals. Ordered a Fuel Pump Block Off Plate from Amazon.Thanks |
		| Does the fuel pump block off plate have the same bolt spacing as the draft tube?
		| Yes. 1 3/4" C to C Bolt Holes. Comes with Gasket and 2 Chrome Bolts. Don't know if Bolts are correct yet. |
		| You can always reuse your old allen head bolts. I didn't get a gasket with mine. Amazingly I was still able to reuse my original gasket from the draft tube.
		| By KULTULZ - 7 Years Ago |
		| "Comes with Gasket and 2 Chrome Bolts"
 Gotta have that BLING ...
 Just a thought to whomever may come across this thread in the future, the road draft assy can be be made inoperative by placing a steel shim gasket behind it and along with a well hidden PCV Sytem, can be made to look bone stock.
		| KULTULZ (11/10/2018)
 "Comes with Gasket and 2 Chrome Bolts" Gotta have that BLING ... Just a thought to whomever may come across this thread in the future, the road draft assy can be be made inoperative by placing a steel shim gasket behind it and along with a well hidden PCV Sytem, can be made to look bone stock.  It just happens to come with Bolts. I will be Painting Engine so it doesn't matter to Me if I use them or not. If you want to use the Draft Tube inoperative You have to cut off the Drain Back Tube before U can block it.
		| That's right OldcarMark. I wanted to mention that and you beat me to it. It's just easier to use a block off plate. I've also heard there's a block off plate used on a VW flat 4 that also works.
		| "It just happens to come with Bolts. I will be Painting Engine so it doesn't matter to Me if I use them or not."
 Sir, that comment was not directed at you personally. Sorry if I upset you.
 "It just happens to come with Bolts. I will be Painting Engine so it doesn't matter to Me if I use them or not." Sir, that comment was not directed at you personally. Sorry if I upset you. Not a Problem. I am thinking about your Suggestion to keep the Draft Tube for Appearance only. I have 2 so I can sacrifice One. Thanks
		| By 56 Parklane - 6 Years Ago |
		| i used the freeze plug then trimmed off the drain tube and put the road draft tube back on  looks stock |
		| By oldcarmark - 6 Years Ago |
		| 56 Parklane (1/20/2019)
 i used the freeze plug then trimmed off the drain tube and put the road draft tube back on  looks stock  I did the same but I cut a Piece of Tin to cover the Opening held in place by the mounting Bolts for the Road Draft. I didn't find the Frost Plug very tight. Could fall inside Oil Pan as the Block heats up.
