Trouble finding an air filter
Posted By 56_Fairlane 8 Years Ago
56_Fairlane
Posts: 575, Visits: 14.6K
57RancheroJim (9/3/2018)
That must be a Lincoln or Merc air cleaner, the snorkle looks larger then a 57 ford. My 57 air filer is 9" OD and is 3 1/2" tall.
http://forums.y-blocksforever.com/uploads/images/588716b1-7221-4609-8a8c-bba0.jpg
I measured my snorkel and it's 9" wide. What could my ACL be actually from?
~DJ~ AKA "Bleach"
First, this might not be helpful, but that housing is not any 1957 Ford air cleaner that I've seen.. Mercury ??
     N.B.-  For info, I've had a problem getting a correct filter for my '57 Air cleaner. The one listed by the largest aftermarket parts outfit in our area, is about  5/16" to high, so the lid does not fit down properly.. Good luck
57RancheroJim
Posts: 729, Visits: 112.0K
56_Fairlane (9/3/2018)
My first guess seeing the larger snorkle was it must be from a larger engine like an FE, but I didn't see anything listed for a Ford. Tbird, Merc, Edsel, Lincoln from 57-64 that matched the size you need, Baffling???.
Check the WIX 42041 for Chrysler products, seem close to the size you need?
Lincoln?
56_Fairlane
57RancheroJim (9/4/2018)
I wonder if it's thr same one I have that's for a Desoto? I'll have to compare the NAPA number I have.
~DJ~ AKA "Bleach"
DJ: I'm not any expert on carbs, but re the Autolite. According to literature I have here, which originated from the former Pony Carburetors in N.Y. state, the choke issues you are having may be caused by the following; Dirt has entered the choke housing & is causing it to act up. The 1.08 series one I have here, from the factory, received it's choke operation air thru a tube from inside the main filter element, to ensure dirt didn't get into the mechanism. Also, on some models of that carb, they were  in OEM installations, fitted near a hot side heater hose attached near the choke mechanism to help ensure it opened promply. I've never seen that, but it might be a case of not enough heat?  And the other day I saw one being used with an electric choke.. And a further note on dirt. Pony Carbs used to rebuilt & tune those carbs for Mustangs etc. Their Warranty was void if you didn't use a "new" gas filter when installing the carb..
56_Fairlane
The choke has a small pipe that gets heat supplied from an exhaust passage in the intake manifold. I replaced the pipe that ran inside the manifold because it was rotted. There seems to be plenty of heat getting to the choke. The only thing is I don't have any heat resistant cloth wrapping the pipe that runs from the outside of the manifold to the choke housing. I can't find any the length I need which is only a few inches total. I don't think the pipe loses much of the heat without it.
~DJ~ AKA "Bleach"
Posts: 3.7K, Visits: 498.2K
The TBird parts people have the insulator for the pipe.  CASCO has it in their catalog - part # 9865.  Different one for a  56 and a 57
56_Fairlane (9/5/2018)
56_Fairlane
That's what I need but unfortunately they have a $14 minimum shipping charge. I think I looked around before and was discouraged at the high cost of shipping something so cheap so I gave up on it.
~DJ~ AKA "Bleach"
