Visits: 14.0K
Visits: 14.0K
Visits: 14.0K
Welding done
Visits: 14.0K
Hi, no photos today (lazy), added tube removed, the hardest part is smoothing the chassis (no filler, just draw filing) so it looks like nothing happened Prepping the frame for paint, this thing is scratched to death all around the engine.
Visits: 14.0K
Visits: 14.0K
No work today, found a lot of Y Block parts on Face Book Market Place, for $250.00 I bought a 292 block with a new 3.800 bore (EDB) new cam bearings installed, 312 crank with a new grind the mains turned down to 292 (still has the oil slinger) a new set of cast pistons to fit the bore, a set of 2 molly rings, a new set of Milling lifters (Chilled Iron), 4 bbl manifold (large flange) 2 sets of ECZ-G heads one set stripped and crack checked, one set complete and not checked, 2 1957 distributors (one rebuilt with new cap and all small parts), 5 sets of valve covers, 2 valley pans, 1 pair of exhaust manifolds (mismatched), a stick flywheel and a worn out clutch , a set of reman rods with bearings to fit the crank, a brand new water pump, starter, generator (used), an engine cart, a set of .030 292 forged pistons (maybe used but nice) and a bunch of small parts, this took all my work time, I'm in Long Beach and the parts where in San Diego (next to John Mummert  and a free Mig Welder.
Visits: 31.2K
Nice score.. Never anything for Y blocks listed around here..
Dave
Visits: 14.0K
Visits: 14.0K
Now sanding the frame for paint, this is hard have to sand all around the tubes.
Visits: 14.0K
