Dragster Engine
Posted By Cliff 8 Years Ago
Cliff
Posts: 908, Visits: 14.0K
Installed
http://forums.y-blocksforever.com/uploads/images/0f9b088e-3537-4337-bc5e-7ab8.jpg
http://forums.y-blocksforever.com/uploads/images/56953fc8-22a1-4fa8-b631-1577.jpg
Cliff
All day making a mock up motor plate, almost done, the hardest part was finding the crank center line in relation to the rear end, now to transfer it to make a real part.http://forums.y-blocksforever.com/uploads/images/6b900047-9224-46f9-bd4f-a2d1.jpg
Cliff
More work on the motor plate.
http://forums.y-blocksforever.com/uploads/images/76f705d7-ed1d-4242-aa09-a239.jpg
Posts: 7.6K, Visits: 206.1K
How thick is the material for your adapter plate?  For aluminum adapter plates, I like using ½” thick.
Cliff
This is 7075 .250 thick, however there is a .750 adapter between it and the block (still need to make it)
Cliff
Here's a back yard trick, I used a 2 1/2" hole saw mounted in the rear main (with a bearing), with a centering drill bit, I then leveled the block on the shop floor, found the center of the motor plate
(used a template for the bolt pattern), slid the motor plate on the drill bit, perfect center, (block and motor plate level to the floor) found I needed to correct some of the holes (my poor work transferring them)
http://forums.y-blocksforever.com/uploads/images/f1ce5daf-01c9-4530-869d-81de.jpg
http://forums.y-blocksforever.com/uploads/images/ae2cc144-7005-4ff2-b525-2de4.jpg
http://forums.y-blocksforever.com/uploads/images/7d03cdc7-9fb5-44bc-8d1d-b4bf.jpg
Cliff
More, Y Block holes drilled, used part of a bell housing for pattern.
http://forums.y-blocksforever.com/uploads/images/13f5f84b-7146-4ee2-980e-5ed3.jpg
http://forums.y-blocksforever.com/uploads/images/97287de9-4f3c-4d3d-9c28-ecc6.jpg
Cliff
More work today, motor plate roughed in, took a long time.
http://forums.y-blocksforever.com/uploads/images/482dc246-f78d-4a7f-9f05-5f99.jpg
http://forums.y-blocksforever.com/uploads/images/129e5858-5a8a-44d6-b87e-b5e0.jpg
http://forums.y-blocksforever.com/uploads/images/5bbff897-b2ca-4cae-a251-f1ff.jpg
http://forums.y-blocksforever.com/uploads/images/3af896f8-c6df-4e29-bdc6-51db.jpg
Cliff
http://forums.y-blocksforever.com/uploads/images/2f98abba-3e66-41d6-af5f-3d0d.jpg
http://forums.y-blocksforever.com/uploads/images/5c3578f4-7ef7-4d8b-8df6-bc52.jpg
Fitting the engine today
http://forums.y-blocksforever.com/uploads/images/0a4a8e7d-382a-43f5-aa9d-6935.jpg
Cliff
New problem, block hits the frame, I'll grind this off tomorrow.
http://forums.y-blocksforever.com/uploads/images/94dc16d2-b904-496f-af9a-ba12.jpg
