Dragster Engine
Posted By Cliff 8 Years Ago
Cliff
Posts: 908, Visits: 14.0K
Well I have others, I may use a billet Mallory distributor that I have, this engine is 11-1  (a real 11-1) cast piston, stock crank and rods .060 over, the good stuff is the heads
(speed master), these heads were a lot better than I expected, I bought them bare, when I checked the valve seats they were perfect, check the guides they were perfect, when I CCd the heads I had to cut one more than the other (about .013) the even up the chambers, 30deg intake seats, 45deg exhaust (Ferrea Valves), Isky springs and retainers (8005), the cam is a Howards Mech flat tappet, the Intake is a real Holman an Moody 2x4, 2 600 Holleys, all good parts in this engine, this is a street engine, I like the the old and the new mixed up.
Cliff
After a lot of work today I had to remove one of the push rod tubes, and maybe one more, just to thick, I also see the head studs breaking through all the intake ports, I think I will make a half moon patch out of very thin stainless steel held in with JB Weld (push rod tubes), I also am of a mind to grind the intake ports and let the head studs show, I don't think the small amount of air transferring between the ports (top port to bottom port) will do anything, I couldn't get good pictures of the problems, funny thing, no problem with the head bolt holes on the bench, only after they were installed on the engine did they start to crack and show, I reached in with my finger nail and broke out a small piece of the port.
PS I guess sometimes you eat the bear and sometimes the bear eats you.
Cliff
Well the distributor now fits, the end play of the MSD is .030, when it's installed in the block it's .025, this took two .030 cuts and one .015 cut (finish cut) to achieve this, the distributor now has end play when installed  (.025 up .005 down), MSD seems to not care about this problem (too bad).
http://forums.y-blocksforever.com/uploads/images/39916ea9-6a24-4b2e-be94-a47f.jpg
http://forums.y-blocksforever.com/uploads/images/8b74fba5-9b2c-4420-ac85-8522.jpg
http://forums.y-blocksforever.com/uploads/images/4d0be0c2-a156-4cba-9955-6035.jpg
http://forums.y-blocksforever.com/uploads/images/f3d116ae-d102-4dcb-8c88-7398.jpg
Cliff
Hi guys, still working today, here's the head bolt sleeves, this material was hard to find, they need to be 3.250 long, they fit (tight) with no reaming needed.
http://forums.y-blocksforever.com/uploads/images/c1c04246-bf72-46ab-831b-beed.jpg
http://forums.y-blocksforever.com/uploads/images/f0e4aa0a-1fbe-4351-b622-c87c.jpg
http://forums.y-blocksforever.com/uploads/images/3a99197a-1198-4d0f-b081-8c1f.jpg
Cliff
Here's the material I'm using for the push rod tubes, I tried to form this by hand (to hard), Monday I will make a tool and form it on the lathe.
http://forums.y-blocksforever.com/uploads/images/b9cb9740-2a2a-439c-ab5f-38cd.jpg
Cliff
Ok, here's the sleeves for the head bolt holes, they had to be tapped in, only the ends needed to be dressed, heads fit over the studs with no problem, also this is the push rod 1/2 moon sleeve, I wound it on the lathe then cut it to length, glued it with JB Weld.
http://forums.y-blocksforever.com/uploads/images/fcf89750-3be1-4a73-9419-b3a0.jpghttp://forums.y-blocksforever.com/uploads/images/743360d8-c466-4da3-8396-3f39.jpg
Cliff
Installed and spot faced.
http://forums.y-blocksforever.com/uploads/images/7b685dd4-c19e-4459-9810-0b68.jpg
http://forums.y-blocksforever.com/uploads/images/58b8f81b-5134-49da-bddd-12c7.jpg
Cliff
No photos today, time for final assembly, am checking all clearances 1 more time ( piston to head, push rods rubbing), so far all's good (I hope), next is the intake manifold (Lexan) have worked out
the nozzle placement (a lot of thought), will run a lot more pressure than most people and smaller nozzles, this helps the fuel to atomize better (raw fuel not running down the side of the port), going to Hawaii next week (!!!), no more work for a bit, will go to the swap meet in Hawaii (parts? well maybe a shirt),
Posts: 3.7K, Visits: 323.8K
Cliff, are you sure you want to go to Hawaii with the Hurricane bearing down on it?
Cliff
I paid for the trip last year so I'm going, how did you get those big rear tires under you car, my son is putting together a 1957 Fairlane 500 with a 428 that I built and it's about time to pick the wheels and tires.
