Marine oil pan gasket
Posted By grrodder 8 Years Ago
grrodder
Question Posted 8 Years Ago
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 5
Hi,  Looking for a distributer who would carry a marine oil pan gasket for my 272 if any one can help it would much appreciated.  Thanks grrodder
Lou
Last Active: 5 hours ago
Posts: 558, Visits: 8.3K
How is a marine gasket different from a car or truck gasket ?
aussiebill
Posts: 1.8K, Visits: 11.4K
Lou (4/25/2017)
lot shorter!!
 Down Under, Australia
kevink1955
Posts: 236, Visits: 237.6K
Lou (4/25/2017)
The Price.
I cannot see what could be different, the block has to be the same, Oil pump intake same. Only thing I can think of may be the drain plug gasket
Posts: 6.1K, Visits: 441.8K
The timing cover is thinner so the timing cover portion of the gasket is different.
Last Active: 4 hours ago
Posts: 4.6K, Visits: 37.7K
I think you could cut down a stock gasket to work. Couple of clean cuts back a few inches from the timing cover join and some gasket sealer should do the job.
Last Active: 5 days ago
Posts: 7.4K, Visits: 205.0K
I do as Chuck mentions.  I simply cut out two sections of a stock oil pan gasket at the timing cover seam and punch in new holes where necessary for the marine cover.  A dab of RTV at where the gasket cuts join together seals the deal.
grrodder
Posts: 2, Visits: 5
Thanks for the help
