By grrodder - 8 Years Ago
Hi, Looking for a distributer who would carry a marine oil pan gasket for my 272 if any one can help it would much appreciated. Thanks grrodder
By Lou - 8 Years Ago
How is a marine gasket different from a car or truck gasket ?
By aussiebill - 8 Years Ago
Lou (4/25/2017)
lot shorter!!
By kevink1955 - 8 Years Ago
Lou (4/25/2017)
The Price. I cannot see what could be different, the block has to be the same, Oil pump intake same. Only thing I can think of may be the drain plug gasket
The timing cover is thinner so the timing cover portion of the gasket is different.
By MoonShadow - 8 Years Ago
I think you could cut down a stock gasket to work. Couple of clean cuts back a few inches from the timing cover join and some gasket sealer should do the job.
By Ted - 8 Years Ago
I do as Chuck mentions. I simply cut out two sections of a stock oil pan gasket at the timing cover seam and punch in new holes where necessary for the marine cover. A dab of RTV at where the gasket cuts join together seals the deal.
Thanks for the help
