Sheet metal paint color
Posted By 55 GLASS TOP 8 Years Ago
55 GLASS TOP
Posts: 389, Visits: 31.8K
Hello, can someone help me with the proper color of the sheet metal under the hood of my 1956 Club Sedan, I have decided to detail the engine compartment and I want to repaint all the black sheet metal stuff ,the air horns the mud guards the radiator support you know all the black stuff. I was going to use satin Chassis Saver brand paint but I was told it would cloud up after some time . Just wanted to know if anyone knows what paint and color it was originally .
62bigwindow
Posts: 884, Visits: 14.3K
All the ones I've seen are body color. I'm sure someone with more knowledge can let you know for sure.
Durham Missouri
Lou
Last Active: 5 days ago
Posts: 562, Visits: 8.3K
If you are talking about the inner fender panels, etc i used "Chassis Black"
55 GLASS TOP
Is that a gloss or semigloss or a flat do you have a brand or paint number . I have seen many cars some with gloss some with out I am looking to put whatever was there when new. Thanks for the reply
Lou
I used it on my 56 Glass Top , I bought at the Ford Nationals from Eastwood, I believe it was a semigloss.
55 GLASS TOP
I was told the stuff does not hold up well to ozone exposure I guess the limited time the hood is up is ok with the paint
Posts: 6.1K, Visits: 442.9K
Ozone is a molecule in the air.  Having a hood open or closed will have no affect on exposure.
UV light, on the other hand, does affect materials that are not designed for it and the underside of a closed hood would be out of direct exposure.  That's one possibility.
Posts: 3.6K, Visits: 497.7K
I use either Krylon Satin Black or Rustoleum semi gloss.  I did my 64 with the Krylon and it came out super - a real nice finish.  As for proper color, I know the TBirds were painted  body color for all the underhood sheet metal while the add on parts (power brake, heater parts) were satin/semigloss  black.
I don't know about the sedans, but they were painted in the same shop as the TBirds.
62bigwindow
I misunderstood your question. The firewall is body color and the rest is semi gloss black. I used Rustoleum semi gloss black on my inner fenders,core support and latch panel.
Durham Missouri
55 GLASS TOP
Yes I meant uv exposure my mistake about the ozone. I want to make sure I use the right color and it won't be bothered by gasoline
